Results 1 to 13 of 14
    Chicago, IL
    need help identifying a door
    I have a new customer that has a very old C-store that was previously a white hen pantry. The doors on his reach-in/walk-in are falling off because the bottom hinge carriers are worn out.
    I was not able to locate a brand name on these doors. There are stickers on them, but they info has worn off.
    The bottom of the door has a round "wheel" in it. The wheel is a pivot point, not a roller. On the door frame is a die cast "carrier" that pops into a hole and is held in by a single screw. to install the door you slide it up onto the top pin and then let the wheel drop into the carrier.
    Any idea what brand this might be? I looked online at Ardco and Anthony parts and didn't see anything like this.
    Jul 2012
    Everett, WA
    I'd check with Case Parts or even 3wire
    Oct 2012
    riverside calif
    yup try case parts
    Oct 2011
    Chicagoland Area
    What about using a formakool or something similar?
    Dec 2012
    Dodge City Kansas
    These jobs really get into the baby-sitting area real quick.
    Go inside the cooler, look on the frame for any labels or plates. Usually located near the electrical hookups or where there are connections to lights and switches.
    Ultimately if none is present, this may be the time for the owner to make his decision;
    good money after bad? or replacement and 10 year warranty?
    Most times, when an owner elects to replace instead, it shocks me to see how much they are willing to invest to solve their irritations.
    Good luck.
    Take a photo of the nameplate when you find it. I'd like to see that.
    Russini
    Sep 2012
    WNY
    Have you tried Refrigeration Hardware Supply (http://www.rhsparts.com/)?
    Jul 2000
    Cuenca, Azuay, EC
    What you describe sounds like an Anthony Torquemaster. Does it look like this?
    Anthony Online Parts Store-Torquemaster
    Mar 2009
    Mid-Mo
    Quote Originally Posted by icemeister View Post
    That's what I was thinking. Does it have 4 flat head screws that stick out of it?
    Chicago, IL
    Its not the torquemaster, but it looks similar in the fact that it has a socket for the bottom pivot wheel to drop into.
    The bottom of the door is free to pivot in the socket. It does not appear to lock in, so i do not believe there is any torsion rod inside. Not one of the 10 doors closes on its own.
    The doors are in horrible shape and the owner even brought up the idea of replacing them, but judging on the condition of the rest of the place i doubt he wants to spend any money
    Chicago, IL
    Quote Originally Posted by ahpwilde View Post
    thats the first place I tried
    I've been looking at CaseParts, but without a brand, its hard to find anything without clicking through hundreds of pages.
    Lake Worth, FL
    a picture would be helpful
    May 2012
    Upper Michigan
    Try lowes! Jk I better get out of the reefer section before I get schooled lol.
    Aug 2010
    Garland, TX
    Post some pics, this would help us all on some ideas. There are many options that can be applied.
