Results 1 to 13 of 33
    First Lenox Pulse 21 Gas Furnace
    I just got back from a service call on a Lenox Pulse 21 Gas Furnace (Model G 21Q4/5-10 0-1) This is the first one I have ever seen. Of course, there are not papers for the unit..rental property. I noticed the control module was flashing green so I reset the power and the led changed to solid green. It failed to light and flased again. I checked the inducer (runs) and the pressure switch is closing. I haven't checkd the sparker (looks like a spark plug) or power to the gas valve. I will return in the morning hopefully with a little more information about this unit. I did not see anything about the led code.. steady flashing means??? (probably ignition failure).. any suggestion would be apprciated.. thanks
    Jun 2006
    New Jersey
    Did it even cough, when you reset it? Most common issue with furnace is air flapper material. But there are many other things you need to check.
    G21 service-
    Pulse 21.pdf
    Dec 2012
    columbus, OH
    the pressure switch on a lenox pulse is normally closed and then it proves opened. silly i know
    Dec 2012
    columbus, OH
    also fyi gass pressure for a pulse is 2'' W.C
    in my lumpy chair
    Haven't seen one of those for a while, still have the flappers though
    I dont warranty Tinkeritus
    It did not do anything. No cough... However, I don't hear as well as I use to.. All I could hear was the module clicking..
    Jun 2006
    New Jersey
    Quote Originally Posted by Core_d View Post
    You sure about that?
    What about the flapper material... and the led flashing code?
    Jun 2006
    New Jersey
    For some....not all.
    Jun 2006
    New Jersey
    Quote Originally Posted by Becool View Post
    Your LED flashing just tells you it didn't fire and it's locked out. The flapper material is apart of servicing.
    Please, read the service manual I provided!
    Dec 2012
    columbus, OH
    yea im sure about the pressure switch looking at a schematic now to verify this i have checked this befor they r N.C
    Dec 2012
    columbus, OH
    also reading hear low voltage pin terminals are 24 VAC half rectified DC pulse current and your meter may read higher or lower than depending on the meter instead use troubleshooting guide.
    May 2012
    Upper Michigan
    Do them a favor and get it pressure tested, just condemned one Friday.
