Results 1 to 7 of 7
12-16-2012, 10:21 AM #1
New Guest
- Dec 2012
- Sacramento
- 3
W7100B obsolete heating controller
Has anyone found a decent replacement for this 6 stage discharge air heating controller?
12-16-2012, 11:12 AM #2
I'd try your Honeywell rep and see if they can cross it with something modern.
Chaos equals cash$$$
12-16-2012, 02:43 PM #3
I redid a MAU awhile ago with a W7100B. It was controlling 6 stages of electric heat.
I used a EasyIO controller and then used a 0-20mA signal to a Kele sequencer for the electric heat.
You could use pretty much any controller you prefer that put's out a 0-20mA or 0-15vDC signal. You can also really use 4-20mA and 0/2-10vDC.
Here's a link to the Kele product-
http://www.kele.com/transducers/ucs-621e.aspx
If you don't have the means for a custom controller, then you could just use a Honeywell T775 with the Kele sequencer. You are going to have to tweak the Kele abit, because the T775 is 4-20mA.
12-16-2012, 04:53 PM #4
New Guest
- Dec 2012
- Sacramento
- 3
Thanks all!
12-16-2012, 06:29 PM #5
Do you need all 6 stages? W775 has 4 stages.
ENJOY THE RIDE
12-16-2012, 07:05 PM #6
Professional Member*
- Apr 2011
- Coastal Maine
- 565
12-16-2012, 07:37 PM #7
New Guest
- Dec 2012
- Sacramento
- 3
Yeah 3 two stage heat exchanger set up, I researched the T775 and I can get an expansion module, I've actually used this controller on a boiler system, don't know why I didn't think of it!
