Results 1 to 12 of 12
    May 2012
    Upper Michigan
    Start of boiler re pipe.
    I have shown pics of this job before but after two years and him wanting to sell his house he finally called me back.
    This is the old piping.Click image for larger version.
ID:	337321Click image for larger version.
ID:	337331Click image for larger version.
ID:	337341Click image for larger version.
    And the start of the new. Air eliminator will get installed when the guy gets it.
    Jul 2009
    Columbia, MD
    looks good so far. keep up the good work Joe.
    May 2012
    Upper Michigan
    Thanks, the tie ins will suck but it will be nice in the end.
    Anderson SC
    The old piping a looks terrible, had to be DIY. New looks really clean, nice job.
    May 2012
    Upper Michigan
    No DIY, local contractor lol. The 011 taco feeds 2 bedroom worth of fin tube with 3/4 pex, boiler short cycles like crazy.
    Oct 2011
    Chicagoland Area
    Gotta love PEX. Can repipe a 3 story house in under an hour Glad they don't alow that stuff here.
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    May 2012
    Upper Michigan
    That's for sure. On a boiler they are supposed to use an oxygen barrier pipe and none of the tube in the house is. Now everything has to be brass or stainless or it will rust out.
    in a house, Appomattox, Va.
    You can use a heat exchanger to separate the iron side from the pex side of system. If its a benefit.
    Col 3:23
    s chester county,pa
    I have used indirects as the heat exchanger on many of these less then properly done jobs with great results. Although I have mostly done commercial work. Cost didn't matter. Indirect on a 256 tekmar for reset.
    May 2012
    Upper Michigan
    Quote Originally Posted by billygoat22 View Post
    The boiler is a stainless HX so I don't see any real benefit, still would need pumps on the pex side. If it was a cast boiler it might be an idea though.
    Feb 2007
    Central NJ
    wow, what a nightmare!!!!!
    You have to pay your due's before you pay the rent!
    Colorado
    Very nice, what goes where????
    Any job big or small,do it right, or not at all !!!
