Results 14 to 26 of 29
Thread: sequencer
    Jan 2012
    Springfield,Il
    Quote Originally Posted by dandyme View Post
    what's weird? the contactor or what it did?
    not so sure the problem isn't still there.
    it's either a stuck sequencer a meter and knowing how to use it would inform you of that condition or there's something shorting across the element.
    lol was neither & trust me bud have meter & know how to use it. Also what the sequencer was doing. replaced with contactor. insulation looked fine but may have blown up when the blower came on concentrating heat on wall behind sequencer thought of that after the fact. So gotta go back to check. Wasnt so much stuck because when i took the door off & cool air entered the sequencer would open up!
    Dec 2012
    columbus, OH
    how many coils are on the seq. ?i woulld think bimetal is just getting week
    Dec 2012
    columbus, OH
    let me clarify how many heating coils is it controling?
    Jan 2012
    Springfield,Il
    Quote Originally Posted by Core_d View Post
    2 heating coils. Replaced seq. did same thing.
    Dec 2012
    columbus, OH
    i would have to guess a temp. issue if both terminals are staying closed and the replacement did the same thing why its to hot is another issue do amp amp draws on the wires that would be my humble
    Nov 2012
    Georgia
    I don't like sequencers, but the manufacturers use them for price I guess. I almost always replace with contactors.
    Jul 2010
    Eastern Kentucky
    I wonder what the surface temperature was at the location where the sequencer was mounted? Also at what temperature does the sequencer contacts close..... This calls for an all out investigation using the scientific method.
    Question: What is causing Sequencers contacts to be closed and allowing completion of circuit to heating elements
    Hypothesis: Excessive heat from cabinet is transferring, in the form of conduction, directly to the bi-metal of sequencer thus causing contacts to close
    Prediction: Heating the mounting base of the sequencer shall ,at certain temperature, close contacts allowing conduction of electricity to flow through contacts
    Testing: Take the sequence at fault and clamp temperature probe to base of it, place multimeter leads across M1 and M2 and set meter on the ohms scale, preferably audible scale, then proceed to heat the base of sequencer with external heat source and record at what temperature the contacts close. Record your analysis and repeat test 3 more times. Also conduct this test on new sequencer out of package. Then with furnace running measure the surface temperature where the sequencer mounts in cabinet and record your readings via#2 pencil.
    Data: place your analysis here:
    Conclusion: State your final conclusions here and present graphs and table charts to confirm your findings.
    Dec 2012
    columbus, OH
    manufacturers use them to save the homeowner on energy bills. Starting tomany components at once can raise your price on kwhs for the rest of the month and anyways if its so hot the seq. wont open its not a very efficent system wouldnt you say?
    Jun 2001
    Moore, Oklahoma
    Peak demand is figured over a 15 minute period, not at any one instant. It only affects those who have smart meters with peak pricing plans and certain commercial customers. IMHO it's better to split the heating load into stages controlled by the thermostat.
    Dec 2012
    columbus, OH
    i thank alot of ppl do have smart meters i know i do i also have a peak pricing plan. I delieave in my neck of the woods peak pricing is determined by kw used in an hour
    Dec 2012
    columbus, OH
    I know this is an old tread but, are you telling me when a seq. is being closed by ambient heat replacing it with a contactor and being done with it in no way affects the customers energy bills compared to determining the actual fault and fixing it. Peak pricing was not the only effiency issue in this situation
    Jun 2001
    Moore, Oklahoma
    Depends on your plan. Plan very GREATLY, be sure to look your up. In our area consumers can pick from 3 summer plans. Standard, TOU, and VPP. Everybody is on standard during winter months so heat sequencing doesn't matter to power bills. Smarthours is the plan that our utility is pushing right now.
    Jun 2001
    Moore, Oklahoma
    The ideal solution is to use a thermostat with multistage capabilities that would only bring on the extra banks of heat strips as needed. The 1st 10KW could be brought on by one contactor through W1, the 2nd 10KW contactor brought on by W2.
    If a multistage thermostat isn't practical time delays or outdoor thermostats could be used to control when the 2nd bank of heat is activated.
    Another strategy with heat pumps involves setting up one 10KW bank of heat connected to W1 of the thermostat and the other 10KW bank being activated by the defrost board of the heat pump. If the heat pump can't keep up the thermostat will call for 10KW heat, when the heat pump goes into defrost the other 10KW will come on. Once the heat pump catches up electric heat is dropped. A simple wiring change achieves this, no additional parts required.
