Results 1 to 2 of 2
12-15-2012, 05:12 AM #1
Professional Member*
- May 2007
- Central NJ Area
- 669
Large Fan powered Humidifier Issues
The Humidifier is A Carrier Large Fan Powered or an Aprilaire 700.
Has anyone had any problems with Aprilaire Humidifers having to much water supplied to the distribution tray? I replaced the orifice with the OEM part located after the solenoid valve in the feed tube. After, I still had too much water being supplied. The only other cause i could determine is that of the water pressure being very high I did not have a tool to check the house water pressure. Has anyone encountered such an issue?
12-15-2012, 10:27 AM #2
- Jul 2012
- Cincinnati ohio
- 103
I have seen too much water making it through even with the proper orifice installed. Usually at that point I close the valve some and adjust it by eye. It's definitely not scientific but I haven't had any complaints....yet.
