Results 1 to 9 of 9
    Mar 2010
    replacement gas valves
    do all gas valves come setup for natural gas?
    even oem replacements?
    Jan 2011
    Metro Atlanta
    NO, it can be set up for LP, but you usually have to ask for them, but if you ask for a natural gas valve you will be ok.
    The opinions expressed by me are not that of my employer.
    insulation modern marvels
    http://www.youtube.com/watch?v=g37riSkyZzM
    Mar 2010
    tks for reply. wasnt sure. this area is mostly lp and i got replacement valve in with no info on what its setup for. will have 2 call mon. furnaces we get have to be converted to lp so i assumed valves were same
    May 2012
    Upper Michigan
    Most always they are nat, look in the box for a lp kit they usual send one with them if its a Honeywell valve. Also it should say what pressure it's setup for so that will tell you
    Mar 2010
    nothing in box. pretty sure ill need springs for lp. was 2 stage valve. think it said 1.5 and 3.5. dont rem offhand. will find out monday. tks for reply
    Jan 2011
    Metro Atlanta
    3.5 is natural gas..
    Nov 2001
    east kansas
    Quote Originally Posted by NY2GA01 View Post
    Not always. Some late '90's Carrier package units had 3.5" L.P. manifold pressures.
    Beware of advice given by some guy on the Internet.
    Jan 2011
    Metro Atlanta
    Quote Originally Posted by Milk man View Post
    Interesting.
    Learned someething new today.
    That tripped up more then one the already.
