Results 1 to 13 of 14
    Oct 2009
    aiken s.c.
    non contact voltage detector
    Saw a new duel voltage non contact detector at H D made by KLEIN.Anyone tried one yet?
    I just picked one up this week. Works just fine.
    Northern Colorado
    I just bought one. I had to read the directions on what the three lights mean. It is a dual voltage detector, but can be switched
    to a high voltage only by the push of the button. You can also silence it, which I prefer. But, I have to silence it every time I turn it on...
    Hvac Maniac
    "A negative attitude cancels out positive skills."
    Nov 2011
    Charleston, Wv.
    don't ever trust one of those with your life.....no matter what brand it is.
    Anderson SC
    Quote Originally Posted by 71CHOPS View Post
    x2, my fieldpiece hs36 has an ncv button that i use sometimes but i ALWAYS double check with meter leads.
    Central NJ Area
    I've never had a problem with the few Fluke noncontact voltage detectors ( and a milwaukee). I mainly use them to see if a wire is energized when troubleshooting. I never use it in any situation where i would be cutting or touching any of the leads/legs. I always double check with my DMM. I also always check the NCV detector on known lives wires before i even begin to use it.
    Its just a device to do a quick check to see if there is any voltage present. Always use a DMM before preforming a repair or modifiying any electrical component or device. Also ALWAYS check the devices operation on a known live wire before using. Cheers
    Dec 2012
    Rancho Cucamonga, CA
    I have been using the last couple of weeks as a back up. It is nice, and its KLEIN! Not that I'm biased at all.........
    Oct 2008
    ohio
    Got one also it works great for trouble shooting safeties and pressure switches
    S.E. Pa
    The Fieldpiece SC77 has a NCV function in the jaws (24-600volts at 50-60 Hz). Handy when you NCV stick isn't around. Always confirm no voltage by confirmed working DMM before touching circuits.
    My SC77 obviously has that function. I only use it because it makes a cool sound. Other than that I don't trust it
    Sent from my SGH-T999 using Tapatalk 2
    May 2011
    Oklahoma
    A coworker has one, I don't like it. Too many butttons to push (LOL), it beeps and flashes, I'm never sure what mode it's on or if it's on at all and I don't care to learn. I like my old Greenlee, turn the cap and it's on. Another that I use is a cheapie that just lights up red, doesn't turn on or off, and I don't even think you can replace the battery.
    Jan 2010
    Quote Originally Posted by matt1124 View Post
    You're kidding, right? It is a single button to turn it on, and it only has 1 button. Even if you don't want to read that Blue is 24v mode, and green is higher than 50v mode, you just have to know that red is detecting, and any other color is "on".
    Nov 2011
    Charleston, Wv.
    I'm kinda surprised so many people rely on these things. I've always considered them to be a bit of a novelty item. too many false negatives i guess.
    of course i consider ANY electric circuit to be energized.....even when I'm 99% sure it's not, soooooo.
