Results 14 to 26 of 27
    May 2012
    Upper Michigan
    Quote Originally Posted by SBKold View Post
    Some people say your stuff gets picked apart and I'm not trying to be that guy.
    But gravity makes a good point and wonder what your thought of positive air pressure in evap condensate against negative pressure in fau?
    The cond line is very short and sweet but condensate from coil in cooling could fill hx in fau?
    Oh and ive got some pictures to get online from this month......so I'm sure there is plenty for me to get beat up over.
    Everyone is a critic lol. I have a sheetmetal background and Jim puts me to shame, everything is clean as a whistle.
    Jan 2011
    I understand what you are saying. The drain for the furnace comes out in a 1/2" cpvc street 90. It is slid inside the 3/4" pvc 90. There is an air gap around it. So if the drain does back up, it will flow out around that fitting rather than into the furnace. Picking up what I am laying down?
    May 2012
    Upper Michigan
    So jimmy how do you layout your metal? By hand or machine?
    Tallahassee, FL
    Quote Originally Posted by jimmyed View Post
    What about the positive air pressure?
    Phoenix, AZ
    Looks great. Good job.
    Jan 2011
    Make it on the job its done by hand. Rest is done on computer and cut out with plasma table.
    Jan 2011
    It will blow out around the fitting? The 2 are not glued or even a tight fit. Never had a drain issue and have done a ton of these the same way. There is a trap inside the furnace on the collector box. No pressure or vacuum there.
    May 2012
    Upper Michigan
    We have a layout table also, your fittings look like the ones I make, sled boots and stuff. I don't do to many radius bends anymore since we don't have a roller anymore. We also don't have a plasma table which would be nice.
    Jan 2011
    They can make about anything that will fit on a sheet of metal.
    Jun 2011
    Houston area
    Old Lennox replacement. Believe that coil of 1/4" line worked as a metering device back in the day?.........
    That's EXACTLY what it is. Nice job!
    The picture in my avatar is of the Houston Ship Channel and was taken from my backyard. I like to sit outside and slap mosquitos while watching countless supertankers, barges and cargo ships of every shape and size carry all sorts of deadly toxins to and fro. It's really beautiful at times.....just don't eat the three eyed fish....
    LMAOSHMSFOAIDMT
    Jul 2012
    Cincinnati ohio
    I like how you raise the unit up to take full advantage of the filter. So many times I see a furnace with a 20x25 filter rack and but the actual opening is somewhere around 16x25. I've never done install but if I ever do I hope in looks half as good as yours.
    Aug 2008
    San Clemente, CA
    Very nice. Good idea to set it all on a 32" plastic pad.
    Jan 2011
    Quote Originally Posted by 2141 View Post
    Thanks, All the bigger systems get a base under them. Bigger as in 3 ton plus usually. I would rather use the bigger filters. Got 16x25's too. They are good filters. I changed 2 that had been in since 07 yesterday. Furnace still clean as a whistle inside.
