Results 1 to 2 of 2
    Accurate Hygrometer Recommendations
    Hi all,
    I've recently got a new job at a university and am tasked with designing a control system for a small, experimental HVAC system. Many of the components have already been selected, leaving mainly sensors to be determined.
    I'm looking for recommendations on an accurate hygrometer. The system is intended for very fine control, and I will be using an OMRON E5EN-H controller so a display is not necessary.
    Thanks!
    Mar 2011
    North Carolina Piedmont Area
    I have used this before in a UL test lab. Its great for wet bulb and dry bulb readings as well as in-put and out-put
    _____________________________
    Trouble shooting is not part of the repair........understand the symptoms and you will find a solution
Comfortech Show Promo Image
Comfortech365 Virtual Event
