Results 1 to 13 of 15
    Lehighton, Pa.
    Bypass humidifier question
    My dealer will be installing a bypass humidifier on my Infinity furnace. Is it better to use hot or cold water for the supply, and why?
    Aug 2001
    Pavilion, NY
    Hot water. The evaporation rate is higher.
    Oct 2010
    Hot
    Dec 2010
    Hot
    In a machine room
    Hot
    Worry is a really gross misuse of one's imagination. -- PHM
    Madison, WI/Cape Coral, FL
    Humidifiers use 3-4 gals. of water per hour. Three gals of hot water cost $.07 at $.10 per kw. Could easily be $1-2 per day. A heater set at 130^F with a 20 ft of copper tube will deliver water 20-30^F below the supply temp. Assuming 100^F water into the humidifier, evaporating 1 lb. of water uses 1050 btus. Most homes may use 4 lbs. of moisture per hour. This is 4,000 btus per hour. 3 gals. of water at 100^F down to 70^F is only 700 btus. and cost $.70. The other 3200 btus must come from the furnace with much cheaper heat source, usually less than half the cost. Possibily with natural gas water heater, the hot water supply is more reasonable.
    I suggest using cold water and increasing the air flow of the by-pass humidifier by adding a 200 cfm duct fan to increase the evaporation rate of slow furnace.
    Regards TB
    Jun 2007
    Greenwood Indiana (Indianapolis)
    Hot water because the heat pump's supply temperature isn't what a gas furnaces is. It will work either way though.
    As iron sharpens iron so one man sharpens another Proverbs 27:17 NIV84
    Hot.
    Athens, Ohio
    Several years ago at a seminar hosted by Skuttle, the rep said cold water is better. He was a technical rep, not a sales rep. His presentation and answers were very knowledgeable.
    Apr 2003
    Maple Grove, MN
    In theory, hot water will evaporate better and you will use less water, but in reality it won't matter much, since either one will be at about room temperature by the time it makes it from your plumbing, through the little 1/8" tubing, and into your humidifier to be evaporated.
    If it isn't too late, I would check into having a fan powered humidifier installed instead. They work a lot better and use less water, and are usually easier to install.
    Quote Originally Posted by ammoniadog View Post
    Refreshing! Also the little bit of heat left is nothing compared to the amount of heat to evaporate water. It's all about air velocity through the pad. VS fans do not get enough air through a by pass humidifier. A 6" duct fan in the bypass duct also does a great job.
    3 gals per hour of hot water counts up and cost a lot of $.
    Regards TB
    May 2008
    Missouri
    Totally agree with bear. Use cold water as hot is simply too expensive for the minimal increase in humidity. If your unit is variable, just add the booster to the bypass pipe. We seldom sell powered humidifiers as they are more complex and fail more often. Non-powered bypass are simple and work fine, and have for years and years!!! Just make sure and change the pad yearly!!
    Lehighton, Pa.
    OK, 6 votes for hot and 4 for cold. Now I'm really baffled. While everyone has opinions, who should I, being the novice listen to?
