Results 14 to 26 of 28
Thread: Have a leaker CVHE ,
12-13-2012, 08:23 PM #14
12-13-2012, 08:29 PM #15
Why waste your time trying to tighten compressor bolts , they dont come loose and on the newer machines theres no O ring in there anyway , all you are concerned about is the flat gasket joints.
Whooo Hooo spring at last , time to get the toys out ........vrrrroooooom !!!!
12-13-2012, 08:47 PM #16
Well that was a waste of half of a night
, but the important thing is that I learned something , I guess I need to pay better attention , point well taken .
thanks for all of your post your time and expertise is muchly appreciated .
12-14-2012, 12:41 AM #17
Thank you Klove for replying the reason I was asking about the metal to metal seals was because the Trane Tech that worked on one of the CVHE here had cut all the insulation of around the compressor and and suction 90 degree elbow and retorqued all the bolts , I figure if he was doing it there must of been a reason , very green and trying to learn .
12-14-2012, 12:47 AM #18
Healey Nut I was asking about the metal to metal seals was because the Trane Tech that worked on one of the CVHE here had cut all the insulation off around the compressor and and suction 90 degree elbow and retorqued all the bolts , I figure if he was doing it there must of been a reason
12-14-2012, 09:55 AM #19
12-14-2012, 09:58 AM #20
Professional Member*
- Aug 2009
- Prattville,Alabama
- 1,104
12-14-2012, 02:32 PM #21
12-14-2012, 02:58 PM #22
- Aug 2009
- 1,104
12-17-2012, 09:51 AM #23
When the sealant they use on the metal to metal flanges is still wet, I apply final torque within an hour of putting the flanges together. The number is not as important as having even surface tension on the flange all the way around. All of the compressor bolts are 5/8" grade 5. The torque spec for them is 120-165 ft./lbs. The most important thing to take into consideration when you're trying to evenly torque the bolts is how clean the threads of the casting and the bolts are. If I can't easily thread every bolt into every hole by hand almost all the way with a tiny amount of never-seize on the tip, they're not clean enough, in my mind, to get a consistent torque on the flange. If the bolts give resistance, they'll make your wrench "click" prematurely. The sealant used at the factory hardens from the inside out, and once it's hard, the bolts will not come loose. If you have a leak on a compressor flange, you have to take it apart to fix it right. No shortcuts, unfortunately. One thing I can tell you is don't put 30-35# on the econo bolts. In my experience, the 14-16# factory spec can even be too much. I've gotten used to going by feel and sight on rubber gaskets. If the gasket is pushing out of the flange, it's too tight.
Truth is still truth, even if no one believes it. A lie is still a lie, even if everyone believes it.
"It's called the american dream because you have to be asleep to believe it" -George Carlin
"A nation of sheep begets a government of wolves" -Edward R. Murrow
"I have problems just like you. One time, my dancing horse almost fell into my car elevator" -Mitt Romney
Buy american made goods & support locally owned businesses!
12-18-2012, 05:24 AM #24
Thank for the great info Rob , I appreciate your time and expertise , cheers!!
I appreciate your time and expertise for any of the question I ask
Living the dream!!!!!!
12-18-2012, 08:58 AM #25
A recent conversation between myself and one of my colleagues went like this:
"How do know what an inch is? How can you precisely measure it?"
"I don't know, with a micrometer?"
"No, just look down when you pee"
"I'd have to look down and then divide by 12"
12-18-2012, 08:35 PM #26
No problem, Troy!
On second thought, I don't wanna know!
Now that's funny!
