Originally Posted by
MIRADAMANia
A friend asked me about humidifying his new home with wood floors, walls and ceilings. Its located in central Michigan and is about 1000 sq. ft. He is on the road for weeks at a time and can't fill and maintain a room humidifier. He has in-floor heat (no ducts). Is there something he can mount on a wall and hook a water supply line to which can automatically humidify his home while he is gone?
Thanks!
I have had good results using a by-pass humidifier with a 6" duct fan ducted to/from the space. Slow the water flow to a slight over-flow to avoid excess water useage. The duct fan also works good with low speed furnace blowers. The duct fan increases the air flow through the humidifier which dramatically increases the evaporation rate of the humidifier.
Regards TB
