Results 1 to 12 of 12
    Las Vegas, Nevada
    Walk-In Freezer Not Holding Temp
    Found the system COMPLETELY flat on Charge. Looks like someone tried something clever. Them clever guys are turning out to be my best referral source...
    Click image for larger version.
ID:	336271Click image for larger version.
ID:	336281Click image for larger version.
    The views and opinions posted here are my own. They do not reflect the corporate policies of my employer and will most likely get me fired at some point.
    Mar 2009
    Mid-Mo
    Is that the magic "solder"? Doesn't look like there's anything on there!?
    Feb 2007
    Fremont, Indiana
    No way!
    Solder compound? The stuff in a red bottle?
    sent from my Samsung Galaxy Note
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Oct 2011
    Chicagoland Area
    WTF is that? Some type of glue?
    Local 597 Service Fitter
    Metal Trade Journeyman
    PAY ME NOW OR PAY ME LATER
    It was working when I left...
    WWFD
    Feb 2007
    Fremont, Indiana
    Quote Originally Posted by kamersoutdoor View Post
    No way!
    Srry,
    "Solderless Copper Bonding"
    A Einstein
    Cincinnati, Oh
    I thought it was called:
    HVAC Super Pro
    Or something stupid like that. I remember reading "you'll ask: what did we do with leaks in walls, before hvac super pro?"
    We used a dang torch. and people were happy at the end of the day.
    That product should be named HVAC Super Hack.
    "Just get it done son."
    Dad adjusted
    Las Vegas, Nevada
    I don't know what product it was. It was red, resembled a Loctite product, and I was able to break all joinings with only my hands. Whatever they used, it didn't work.
    I've used the HVAC superpro on boiler water pipes once. They were in a wall an needed to be cut and capped and I had to work entirely by feel, they could not be seen to use a torch. It worked excellently.
    The stuff I used was purple in color so it probably is not what was used in this case.
    The SuperPro has like 10 warnings all over it that you must sand the fitting with coarse grit cloth and LEAVE THE FILINGS on the pipe and fittings. If you wipe them off it won't harden properly.
    Oct 2012
    La Crosse, WI
    So was the drier and solenoid put in recently or has it actually been able to run for a while with all the joints glued together with red loctite?
    Las Vegas, Nevada
    Quote Originally Posted by Mike19 View Post
    One branch of a chain we picked up several months ago, first visit there. Have to assume it ran for a while.
    Feb 2012
    Toronto Canada
    That is so bad it isn't even funny it's sad No pride at all!
    Did the red magic glue make it hard to solder it? How much of a charge did he loose?
    Las Vegas, Nevada
    Quote Originally Posted by OldSchoolMech View Post
    I was concerned about bits and chunks of that stuff finding its way into the TXV, so the solenoid valve and all copper in that section were replaced. With a torch and silfos. One jug of R404a later, had a cold freezer.
    It's too bad, it would be really cool if there were some 'magic glue' that actually worked.
