Results 1 to 13 of 29
    Sep 2012
    cape coral FL
    semi hermetic comp
    my first one tomorow tips or info would help big time thanks
    Are you replacing one?
    If so, what type?
    Mar 2009
    Mid-Mo
    Don't let Frank trick you, he's forgotten everything about compressors. How can we help you out bud?
    what are you doing with that semi-hermetic?
    Are you, as ST asked, replacing it?
    Servicing it?
    Starting it up?
    Looking at it meaningfully?
    Bench pressing it?
    Standing on it to reach the top shelf?
    You need to help us before we can help you...
    Mar 2009
    Mid-Mo
    Bench pressing it?
    Did you ever see that commercial for a gym where all the guy says is "I pick things up and put them down"??? That reminded me of that!
    Just so you know!
    I installed some small cv rooftops today.
    I barrowed my neighbors ladder.
    She does not even know.
    Quote Originally Posted by ryan1088 View Post
    Mar 2009
    Mid-Mo
    Quote Originally Posted by supertek65 View Post
    Just so you know!
    I can't top that...I did some BAS work today.
    Sep 2012
    cape coral FL
    sorry did not get back on the computer last night. yes it was a replacement its a 40ton unit with 3 OD fan motors that i think load or unload off the discharg line. The comp was sent to us with no oil in it i know how to get the oil in but how do you get it dialed in just right?
    Mar 2009
    Mid-Mo
    Quote Originally Posted by hvacman2213 View Post
    It's all good, we like giving people a hard time.
    The compressor will say how much oil it holds, I'd start with half-ish of that and go from there. There are lots of ways to pull off putting oil into a system. I have always used an oil pump, I'd be interested to hear who does what.
    Sep 2012
    cape coral FL
    we used a pump as well. now there was 2 valves on the top of the compressor by the low and high pressure ports. valves that can be adjusted with adjustable wrench is that some sort of equalizer?
    Mar 2009
    Mid-Mo
    Valves like a solenoid valve? Pictures?
    If I had to guess it would be unloaders.
    Sep 2012
    cape coral FL
    how do you set your unloaders?
