Results 1 to 13 of 16
Thread: 90 PLUS carrier
    Jan 2002
    I'm having trouble getting this furnace fired up. The led indicates pressure switch not closing. I checked the pressure switch and it seems to be Ok. I also checked all hoses and seals around inducer housing.I REMOVED intake and exhaust pvc piping. model 58mxa040 serial 1597a00971
    NW burbs of Detroit
    Did you trace out where the voltage drops off?
    Jan 2002
    no can you explain that.
    by the way I forgot to mention I found water in inducer housing
    NW burbs of Detroit
    Uhhh.. that's normal for a ninety plus. At least a little bit.
    How far did you get with the contol voltage before it stopped reading?
    Is this your furnace?
    Jan 2002
    It had a good amount of water enough to spill out to the floor. actually I didn't do a thorough control voltage check.When I started the unit it went threw ignition trial and then I checked the code on the board.
    SE Michigan
    This should be in the pros forum.
    “Now the freaks are on television, the freaks are in the movies. And it’s no longer the sideshow, it’s the whole show. The colorful circus and the clowns and the elephants, for all intents and purposes, are gone, and we’re dealing only with the freaks.” - Jonathan Winters
    Jan 2006
    Hamilton Ontario Canada
    Check your condensate drain to make sure it is not blocked. To much water will cause that problem.
    Jan 2002
    Drain is clear
    NW burbs of Detroit
    Where did you check for drain blockage?
    Jan 2002
    trap
    NW burbs of Detroit
    Time to do a diagnostic check on the rest of the system.
    I still need to know if this is your furnace or not.
    There are things you can do with private property that you can't on a service call.
    Jan 2002
    This is private property
    NW burbs of Detroit
    HMMMMMmmmm....
    Why aren't you doing a diagnostic? Your profile says you are a cotractor.
