Results 1 to 12 of 12
    Jan 2013
    Help with T7350 thermostat
    .Hello,
    I have recently installed a used Honeywell t7350 thermostat in one area of our building. I want to make some changes in the program which requires me to get into the software. I have downloaded Tstat into my laptop and purchased a usb to rg46 cable to connect. The problem is that the program in the laptop says there is no connection to the thermostat. Does anyone have any idea why I would not be able to talk to this thermostat. Thankyou.
    are you using "TStatSpec™ Configuration Software"?
    Jan 2013
    Yes I am using TStat Spec
    Atlanta,GA.
    did you tell it to connect ? at top of screen is an icon that shows two wires with an arrow underneath click it
    Jan 2013
    I tried using the connect icon and it still says usb-tim not connected. I'm suspecting my cable is defective.
    Atlanta,GA.
    did you get the cable and adapter from honeywell? there is a cable and a little black box that goes between it and tstat
    Jan 2013
    no, I purchased it on amazon. sounds like i got the wrong cable.
    Atlanta,GA.
    yes it does . the cable you need will have a usb connector on each end then there is a black box with a usb port on it and cable attached about 3 inches long with connector that plugs into stat. if you have not down loaded the options sheet /progamming menu you need to do that too
    Jan 2013
    Could you tell me where i might be able to get this adapter ?
    Southeastern Pa
    Honeywell rep can direct you.
    Atlanta,GA.
    I got mine at united refrigeration
    Jan 2013
    Thanks for your help.
