Results 14 to 26 of 27
Thread: hybrid hot water heater
12-13-2012, 01:21 AM #14If Guns Kill People, Do Pencils Misspell Words?
http://www.youtube.com/watch?feature...&v=2kX_3y3u5Uo
http://www.youtube.com/watch?v=JVAhr4hZDJE
http://www.youtube.com/watch?v=-TC2xTCb_GU
12-13-2012, 06:22 AM #15
- Aug 2012
- nj
- 9
Just like the ice is frozen. ha ha
12-13-2012, 07:17 AM #16
12-17-2012, 11:06 AM #17
12-17-2012, 12:05 PM #18
I haven't done a hybrid water heater. I know they're available in my area. Apparently, the advantage of a hybrid is getting the efficiency of a tankless water heater without the "sandwich" and fluctuations inherent with such systems. A mixing valve doesn't always cut it which is why the mix is done in a reservoir on the tank itself. It's a tankless water heater with a gargantuan mixing reservoir - basically, a tankless water heater that isn't completely tankless, hence the designation of hybrid. That's my simplistic look at it.
There is still a large footprint for such a unit and at double the price, not convinced of the advantage. High demand (150+ Gallons first hour) and high efficiency is the market. The control is flow and/or temperature from what I've read. 2" S636 can be used as well.....200 lbs. Hardness is a big factor too.
12-17-2012, 12:25 PM #19
BAd idea IMO> Unless you have very, very fine mesh screen on the discharge, all that lint will make a dusty mess of your basement. Lint traps don't catch the fine stuff. Even worse the fabric softner chemicals I believe can be hard on coils, if anything possibly coat them and reduce efficiency and capacity.
I alsways wondered if you could cost effectively core drill through a basement foundation and install just enough ground loop capacity for 2-3k BTU and use a larger tank. I have a tankless, but on average, I'm only using 1500-2000 BTU's to make hot water including a recirculation loop. That what desuperheaters put on out geothermal systems. Just a nice steady 2-5k BTU depending on compressor load.
12-18-2012, 06:00 AM #20
12-18-2012, 06:02 AM #21
12-18-2012, 08:50 AM #22
12-18-2012, 09:38 PM #23
- Jun 2001
- Oklahoma City
- 2,573
Defeats the purpose IMHO. Deactivating the heat pump mode when incoming water temps are the coldest. Anybody who has a GAS water heater can attest to how little energy is used to heat water in the summer. $5/mo in gas use with warmer summer water temps?
IMHO tankless electric water heaters are impractical due to he heavy electrical load, some use (3) 60A breakers. Just don't let the HVAC heat strips turn on at the same time, or you will overload a standard 200A electrical panel in a hurry.
12-18-2012, 09:44 PM #24
12-19-2012, 12:16 AM #25
- Jun 2003
- 3,633
I'm going to laugh at all those people that bought electric tankless heaters when the utilities bring demand metering to residential customers. With all the "smart meters" going in, it only takes a click of the mouse to activate peak demand based billing. I bet it will be the norm in 10 years.
12-19-2012, 05:06 AM #26
