    My Evolution system is reporting a "range error" under the service menu - my HVAC guy is researching it. Anyone know what this is? Thanks.
    Jun 2001
    Louisville, KY
    outdoor air and outdoor coil temps are too far apart.
    is the outdoor unit a new model or last year's model?
    The outdoor unit is the older 2-speed Bristol TS compressor based system. The outdoor air temperature sensor does tend to read high. Is this something to be concerned about? Thanks so much.
    Jun 2001
    Louisville, KY
    Can you see the OAT sensor when looking at the unit?
    Yes, it is hanging outside the unit - sort of pushed through a hole.
    Jun 2001
    Louisville, KY
    I'm presuming that you have a heat pump. When the heat pump is approaching a defrost cycle, this will occur. It's a non-issue. If a thermistor actually fails, you will get a different error. I get range errors, too. They only occur when the coil is getting frosty.
