Results 1 to 7 of 7
Thread: duct sizing
    Sep 2010
    miami,fl.
    duct sizing
    can anybody post a good book or website to learn how to calculate return duct sizing, and return grille sizing basically something that can brush me up and better on the airflow side.
    Dec 2010
    Quote Originally Posted by anthonyac1 View Post
    Return air grille = 2 cfm per sq. inch. Example: 14"x6" = 168 cfm
    One ton of A/C is 400 cfm............ 2 ton = 800 cfm. However, I size the cfm to the furnace/ air handler blower. Example: 3 ton blower requires (at least) 1,200 cfm.
    I always go more cfm rather than being right on the money or, like many contractors, not having enough return.
    If your cfm requirements are split (example) 50/50 then, with a 3 ton (1,200cfm) blower, you would need (at least) 600 cfm from one end and another 600 cfm from the other end.
    Now, for duct sizing......... take your cfm requirement, multipy by .02 and add 2.
    Example: 600 cfm x .02 = 12 + 2 = 14"x8" duct. Another example: 1,000 cfm duct requirement..........1,000 x .02 = 20 + 2 = 22"x8" duct.
    There's your book.....free and simple. There is alittle more to it of course, but the above helps our techs determine quickly short falls in systems without enough RA.
    I can look at a home (if the ductwork is easy to see) and let the customer know in 15 minutes if there is a problem with the ductwork and/or return grilles sizing.
    Dry as a bone Tucson
    Here is an excellent and concise pdf.
    Watchman Nee
    Feb 2013
    Fairhope,AL
    Acfixr..Nice pdf!Thank you.
    Quote Originally Posted by ComfortService View Post
    You might glean some knowledge from these too then.............
    Watchman Nee
    check your mail, skydrive has a 35mb file
    St. Pete, Florida
    Thanks Acfixr for posting this info.
