Results 27 to 39 of 66
Thread: Trane heat exchangers
12-16-2012, 10:30 AM #27
- Jun 2012
- rising sun, md
- 71
almost every brand will crack eventually. thats crazy its only like 3 years old. i find a crack i a heat exchanger atleast once a day you got to know where to look, in those dimple welds, cracked eyelets, and right inside the burner tube is the most common. you do have to look and homeowners think your just trying to find something wrong with it. but they way i see it im trying to keep their house safe
12-16-2012, 11:32 AM #28
http://s702.photobucket.com/albums/w...TEwNC5qcGc.jpg
Sent from my BlackBerry using Tapatalk please excuse typographical errorsIf you can not do it right, Why even do it at all?
12-16-2012, 08:51 PM #29
Sorry my photos off my phone didnt work... So here they are the one that i have seen a problem's in seem to be with the 100,000 btu models the transition was not cracked and it was coming from the plastic plate that is screwed on the secondary. the rest of it is stainless i beleive i wish they would of also dont those stainless and not cheap plastic. I hope these forms help contractors and homeowners fight this problem because its wrong........
12-17-2012, 09:18 PM #30
- Jul 2012
- Cincinnati ohio
- 101
12-17-2012, 09:29 PM #31
looks like that one's been apart before.
The last one I had w/cracked header, only time filter was cleaned was when I went and condemned it- twice. She got new one after third header failed.
Wonder how many yrs before next failure?Col 3:23
12-17-2012, 09:45 PM #32
12-17-2012, 09:47 PM #33
12-23-2012, 12:09 AM #34
New Guest
- Feb 2008
- Tinley Park..ILLINOIS
- 5
Just changed one today ,the round button in the middle popped pff thats where it was leaking.keeped getting a pressure switch code,if you pulled off hose and put back on the furnace relights.put in new heat exchanger high temp sealed.9hrs later it started not to light again.going back in morning to change the hose to pressure switch.and high temp seal inducer,anybody have any in put why its doing this.put on a new pressure switch already don,t know what else to check.
12-23-2012, 12:32 AM #35
- Jan 2006
- Northwest Missouri
- 239
chicagojonny, what do you mean by the button in the middle?
12-23-2012, 12:42 AM #36
New Guest
- Feb 2008
- 5
the way they are made on each chamber there is a round hole with a round quater size ring that is pressed on from expanding and cotracting it popped out causing a leak
12-23-2012, 09:22 PM #37
12-23-2012, 11:34 PM #38
New Guest
- Feb 2008
- 5
found my problem bad board it kept the inducer running after shut down
12-24-2012, 09:23 AM #39
Good to hear
