Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 67
  1. #40
    Tinley Park..ILLINOIS
    thanks , it was a single stage,the board had to be the problem all along finding the bad heat exchanger was a bonus
    Sent from my BlackBerry using Tapatalk please excuse typographical errors[/QUOTE]
  2. #41
    Jan 2006
    Northwest Missouri
    Just found one with a crack in the header,and a crack in the inducer bracket that hold the inducer motor will put pic on.
  3. #42
    Quote Originally Posted by eliteair View Post
    That is pretty common with tranes design and first thing I check. But my photos where a result of hairline cracks in the secondary plastic collector box. Only way to see it was to pull it, not sure if u could see the detail needed with a snake camera but I would like to try.
    If you can not do it right, Why even do it at all?
  4. #43
    Dec 2012
    Columbus OH
    Yes I have noticed them with pin holes ,heat exchangers aren't mad like they used to be and the manufacture doesn't carry the 20 yrs like they use to ..Regards
  5. #44
    Quote Originally Posted by techwizard007 View Post
    I am not sure everyone here would agree with me but why not spend a couple extra dollars and make that cover out of stainless or anything other then plastic and I wonder if they would not be having this issue anyone else fell this way?
  6. #45
    s chester county,pa
    had one today that was leaking water on the right hand side above the blower motor in blower compartment.(tux080c942c3) i think its the inducer. alot of sloshing on startup.unit plumb and level. upflow.drains and traps clear. please advise if im wrong. rescheduled pulling inducer and gasket replacement. all ca readings were good. 0ppm in home
  7. #46
    Dec 2011
    Twin Cities Minnesota
    Hey Techwiz...,Goodman has a lifetime on there H.X.
  8. #47
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by Cosmicmuffin View Post
    Most manufacturers have a 20 year or lifetime warranty. certain carrier models have only a 10 year.
  9. #48
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by 2141 View Post
    It doesn't matter the model. I have seen them on every model both 80 and 90 %. Here is a picture I took using my see snake and phone. It right underneath the burner entry Attachment 335651
    Has anyone found any of these lately?
  10. #49
    Jun 2009
    Northwest IN/Chicago
    Good lord, glad I found this thread! This answers my question about how Trane HX's are holding up... Now i'll be keeping an eye out.
    Are these failing HX's you guys are finding not getting enough airflow or something? (in other words any of them fail with proper airflow/ductwork etc)
  11. #50
    Jul 2012
    Cincinnati ohio
    Quote Originally Posted by Gus-Herb94 View Post
    There is no reason outside of design or quality of materials.
  12. #51
    Apr 2012
    Cleveland
    Name:  ImageUploadedByTapatalk 21360888443.635084.jpg
    Found this one today. 9 yrs old.
  13. #52
    Quote Originally Posted by Hvac216 View Post
    I assume that is the tail piece from secondary to comb blower motor?
