Results 40 to 52 of 67
Thread: Trane heat exchangers
12-24-2012, 10:48 AM #40
New Guest
- Feb 2008
- Tinley Park..ILLINOIS
- 5
thanks , it was a single stage,the board had to be the problem all along finding the bad heat exchanger was a bonus
Sent from my BlackBerry using Tapatalk please excuse typographical errors[/QUOTE]
12-25-2012, 01:47 PM #41
- Jan 2006
- Northwest Missouri
- 239
Just found one with a crack in the header,and a crack in the inducer bracket that hold the inducer motor will put pic on.
12-25-2012, 09:03 PM #42
That is pretty common with tranes design and first thing I check. But my photos where a result of hairline cracks in the secondary plastic collector box. Only way to see it was to pull it, not sure if u could see the detail needed with a snake camera but I would like to try.
Sent from my BlackBerry using Tapatalk please excuse typographical errorsIf you can not do it right, Why even do it at all?
12-25-2012, 10:07 PM #43
Yes I have noticed them with pin holes ,heat exchangers aren't mad like they used to be and the manufacture doesn't carry the 20 yrs like they use to ..Regards
12-25-2012, 10:43 PM #44
I am not sure everyone here would agree with me but why not spend a couple extra dollars and make that cover out of stainless or anything other then plastic and I wonder if they would not be having this issue anyone else fell this way?
12-27-2012, 09:22 PM #45
- Jan 2008
- s chester county,pa
- 140
had one today that was leaking water on the right hand side above the blower motor in blower compartment.(tux080c942c3) i think its the inducer. alot of sloshing on startup.unit plumb and level. upflow.drains and traps clear. please advise if im wrong. rescheduled pulling inducer and gasket replacement. all ca readings were good. 0ppm in home
01-01-2013, 10:42 AM #46
Professional Member*
- Dec 2011
- Twin Cities Minnesota
- 114
Hey Techwiz...,Goodman has a lifetime on there H.X.
01-01-2013, 11:40 AM #47
- Jul 2012
- Cincinnati ohio
- 102
01-25-2013, 08:42 PM #48
- Jul 2012
- Cincinnati ohio
- 102
02-01-2013, 01:56 AM #49
- Jun 2009
- Northwest IN/Chicago
- 249
Good lord, glad I found this thread! This answers my question about how Trane HX's are holding up... Now i'll be keeping an eye out.
Are these failing HX's you guys are finding not getting enough airflow or something? (in other words any of them fail with proper airflow/ductwork etc)
02-01-2013, 09:16 AM #50
- Jul 2012
- Cincinnati ohio
- 102
02-14-2013, 07:34 PM #51
Found this one today. 9 yrs old.
02-14-2013, 08:18 PM #52
