Results 1 to 6 of 6
    Sep 2012
    thomaston, ct
    MPO w/indirect tied into wood boiler and 2 copper radiant loops
Size:  48.8 KBName:  ImageUploadedByTapatalk1355086173.633606.jpg
Size:  51.9 KBName:  ImageUploadedByTapatalk1355086192.433721.jpg
    Old:
    May 2012
    Upper Michigan
    Looks nice, why don't you put a ball valve and a drain after exp tank for when it goes bad you don't have to drain the whole system to Change it?
    Sep 2012
    thomaston, ct
    With flow checks and isolation flanges normally I would disagree. In this boilers case I would say good idea since what is involved in purging the radiant zones. Didn't design the piping on this job though. On a normal system I never have any issues just dropping the pressure and isolating the supply to do an expansion tank.
    May 2012
    Upper Michigan
    You can't verify pressure in exp tank without isolating it either. I'm not trying to sound like a old nag lol but it makes life easy.
    Sep 2012
    thomaston, ct
    Yeah I guess that is one good bonus.
    Rochester NY
    Tidy
