Results 1 to 8 of 8
Thread: Heating a Garage
11-20-2006, 02:15 PM #1
- Nov 2006
- 17
This had been discussed a little in a separate post, but I'm looking for recommendations for heating an attached 3-car garage. Garage is about 900 sq. ft with 9 foot ceilings. I live in Wisconsin, so the winters get cold, but I'm only looking to keep things above freezing and warm it up enough (~60 deg) to work comfortably with a light jacket. I wouldn't bother going above 40 on the coldest days. The garage walls, ceiling, and doors are all insulated, and with 2 shared walls with the house, keep the garage above freezing for all but the few coldest days currently.
I'm leaning toward a natural gas unit heater becuase the ceiling mounting gets it off the floor for space and fume considerations. I also like the idea of sealed combustion, although it may not be required for my needs. Any other options, though, are appreciated.
Options I have heard of include:
-Reznor
-ADP Cayenne
-Modine HotDawg
-Dayton
Any opinions or experience on the best (or worst) options are appreciated.
11-20-2006, 03:55 PM #2
Go with the Hotdawg. Its low profile and is power vented. You can side discharge it too.
"If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
11-20-2006, 07:37 PM #3
I put a Fujitsu ductless in mine.
Toasty warm in the winter.
Cool in the summer.
And no worries about nat. gas in the garage.
Then again, I am a dealer.
11-20-2006, 07:57 PM #4
I went with heat pump because of old GTO convertible and 2 sweaty English bulldogs,it is ALL beef out in that garage.
It's NOT the BRAND,it's the company that installs it!!!!!
11-21-2006, 01:05 AM #5
- Aug 2002
- manitowoc wisconsin
- 4,687
Hot dawg has my vote.
Take your time & do it right!
11-21-2006, 09:36 AM #6
- Nov 2004
- Naples, Fla.
- 1,403
You might have your contractor show you some gas fired infra red heaters if your floor plan & usage is open, rather than wasting energy on heating air, it just heats you & your work area.
CAUTION - If you use gas, be sure your contractor takes all appropriate code required steps to keep you safe. This includes limiting your use of paints & combustibles.
11-21-2006, 11:13 AM #7
Member
- Jun 2006
- S. Wis
- 46
I live in Wi. also, the winters do get cold, but not like they used to!!! I think we do get too cold for a heat pump to work on our very cold days (-10).
I would go with a ceiling mounted also, sealed combustion (too many flamables in a gagage, my uncle has a new house because of that very reason!!!)nat. gas.
Check with a local heating conractor (or three) see what others in your area are using sucessfully.
Good luck.
11-22-2006, 10:06 PM #8
Professional Member*
- Jan 2001
- Pamnyra VA.
- 699
go with the infared, i prefer the brand roberts gordon.
