Results 1 to 13 of 15
Thread: Zoned System Ducting Advice
12-09-2012, 09:45 AM #1
- Dec 2012
- 7
I am looking to build a house next spring just north of Winnipeg, Manitoba, Canada. I wish to put in a zoning system to allow for more efficient use of heating and cooling energy and to keep the house consistently heated over varying heat loads. The problem is when I talk to local contractors most do not want to deal with this kind of system or are giving me conflicting feed back.
The systems I would like to install is(and I have yet to get a price on either):
Trane:
-ComfortLink 2
-10 zones
-XR16 heat pump
-Electric Air Handler with 15kW of backup heat
Carrier:
-SYSTXCCUIZ01-V
-8 zones(need to combine 2 basement bedrooms, and storage and basement play room)
-25VNA heat pump
with both systems only main thermastat, master bedroom and basement play room will have displays.
The biggest discrepancy I seem to be getting is how they would plan to run the duct work.
1) Some contractors say each zone needs to have a home run back to the air handler. If this is the case I need to rethink my plans as it would likely be to expensive.
2) Some contractors have said I can put the air handler in the middle of the house have 2 damper motors on either side of it then run truncs down the house splitting off for each zone. This would be ideal but reading through the literature and wiring diagrams of these systems makes me think this is not natively possible with either system and not possible at all with the carrier system. I am pretty sure I could use a small PLC to make it possible with the Trane system(I am an Electrician)
3) None have suggested this but I wounder if it is possible. Same as (2) but remove the damper motors. Assuming everything was sealed well would not back pressure from all the closed dampers prevent air from flowing down the side not calling for air.
The trane system is a lot nicer looking and has a lot more options but Carriers heat pump is much more efficient a HSPF of 13 vs Tranes HSPF of 9.5
I would love any advice and/or quotes on installing the system. I am an electrician and can handle all the wiring of the systems but I don't want to deal with installing of the ducts or heat pump and to what I have read sizing of ducts can be very critical.
Let me know if there is anymore information anyone needs. And thanks for any advice/quotes people can give me.
Prints:
12-09-2012, 10:18 AM #2
Professional Member*
- Feb 2004
- michigan
- 674
why so many zones? will every room be zoned seperatly? how will you be handleing capacity reduction? i really only see four realistic zones.
I am the "Wally". All others are meer imitations of the original.
12-09-2012, 11:34 AM #3
- Dec 2012
- 7
5 on main floor: 1 per bedroom plus main area
5 in basement: 2 bedrooms, media room, play room, storage
Reason for splitting is to be able to set areas as unoccupied. Bedroom walls are all insulated and there are 3 extra bedrooms then I currently have kids.(guests and planned 3rd kid)
12-09-2012, 02:01 PM #4
- Dec 2010
- The Quad-Cities area (midwest).
- 1,762
I agree with Waldo, why so many zones? You said you were worried about cost? Reduce the zones = reducing the cost. But each to his own.
That said, Carrier has a sweet modulating zone system. I'm not fimiliar with Trane. There are different ways to reduce costs. Either reduce the number of expensive dampers which means more ductwork/labor (it also reduces the long term service needs) or use less ductwork and more dampers. Personally, I think you could reduce the number of zones by consolidating some areas. Example: The three bedrooms on the main level could be on one zone. I'm just saying. Good luck. Most contractor do not like, know or want to know about zoning. I worked with one salesman that had a bad experiance with zoning (I'm sure it was his fault, he was dumb as a box of rocks) and never tried to sell it again.
12-09-2012, 02:27 PM #5
yes, you can have your main trunk lines ran without dampers, and then have the individual dampers in the branch supply lines. Carrier Infinity modulating zoning system will work well for this.
12-09-2012, 02:32 PM #6
- Dec 2012
- 7
The trane dampers are only $ at the wholesaler and thermistors are only $ so ducts and Labour are the expensive part. Most contractors I have talked to said I would have to do all the controls once they found I am an electrician and doing all the electrical for the house. I do a lot of comercial hvac control work for a living
12-09-2012, 02:44 PM #7
- Dec 2012
- 7
Thanks that is a good thing to know. George the purpose is to save money on heating bills not upfront cost. Combining the 3 rooms would save me $ but give me less control on bedroom temps. Admittedly I will never likely save the money back on heating bills but I like the control gained by having seperate zones. That said if it ends up it will be an extra $ in duct work I will definetly combine them to 1 zone.
12-09-2012, 02:44 PM #8
Prices aren't allowed here.
12-09-2012, 03:15 PM #9
- Dec 2012
- 7
Sorry. Well without prices(even hypothetical ones) there is no point discussing the zone arrangements other than to say I am willing to reduce zone count to keep project economical.
Thank you for letting me know option (3) will work as this is the cheapest install method. Will it work well is an interesting question which I believe you said it will with carrier.
12-09-2012, 03:40 PM #10
- Dec 2010
- 1,762
12-09-2012, 04:21 PM #11
The Trane isn't a good option. On low, it is 75-80% of high so when 1 or 2 zones calling, you'll be short cycling something fierce trying to keep from freezing up or tripping high head in heating with the 16i. If you must go Trane, the 20i is a much better option.
The modulating Carrier makes so much more sense assuming the Infinity control will drop it down to the lowest rate with low load.
I think if I were building a nice joint in a cold climate, I'd have hydronic heat.
12-09-2012, 04:50 PM #12
- Dec 2012
- 7
I will install the pexs in the basement and garage slabs for future hydronic heating. For now though I want to focus on ducted heat as that can cool also(we have very hot summers also no middle temps though)
If you mean geothermal that would be ideal but the payback period for my house design is 25 to 50 years which I very well may live but can't justify paying up front to my wife.
12-09-2012, 06:29 PM #13
- Dec 2012
- 7
