Results 14 to 20 of 20
Thread: Propane based R22
12-15-2012, 09:03 PM #14
- Nov 2012
- Georgia
- 13
The problem with some blended refrigerants is they have a different glide....meaning in the event of a leak, all the other ingredients may leak out leaving you with pure liquid propane. This stuff makes big fires!
12-15-2012, 09:15 PM #15
propane does have the same boiling point at r22 but its just a lil more combustable.
12-15-2012, 09:19 PM #16
Propane for all your heating AND COOLING needs!why didnt i think of that?
12-16-2012, 11:40 AM #17
- Sep 2010
- miami,fl.
- 319
what happens when the compressor shorts out internally and obviously makes sparks will it blow up???? or not since you need oxygen, i think it will still go
kaaaaboooom???? honestly its messed up think about it you have these hacks throwing it in these systems then here you go replace txv under normal procedures starts a huge fire now its on your insurance company, kind of not fair gotta becareful out there.
12-18-2012, 08:54 PM #18
Professional Member*
- Oct 2009
- Raleigh, NC
- 438
Propane's explosive limits are 2.37%–9.5%. It will not explode below or above these concentrations. It is very common as a DX refrigerant in household refrigerators in other countries and has been for a long while now. The amount required is only a few ounces. It is also widely burned in gas absorption refrigeration systems, so it really can heat and cool!
12-19-2012, 05:40 AM #19
12-19-2012, 04:58 PM #20
- Jul 2010
- nebraska
- 1,176
Correct it needs oxygen to blow. When my reclaim machine failed last week it blew out a mist of refrigerant. Pretty sure that would have been a fireball with propane.
