Results 14 to 15 of 15
    Saint Joseph, MI
    Quote Originally Posted by LKJoel View Post
    I actually did a little experiment on just that this winter. Last year I removed my goodman 75 single stage furnace and replaced with an Armstrong 60 2 stage. House is 1200 sqft, built 1925 with lots of added insulation. This year I disabled high fire, low fire is only 36000 BTUH. So far, results are good, house is very comfortable, with very even temps everywhere. I'm happy with the switch so far. We will see how we'll it holds up when things get really cold, but much better so far
    Seems like a better thermostat should accomplish the same thing. A VP iaq with the right settings should only bring on high stage when really needed.
    I alerts like to use all ghost homes with geothermal as an example. Most rarely needed aux and are only delivering mine 40k in homes that you know soul have had a 60 or 80k furnace installed.
    If you work a had bill backwards you be apprised at how little peak btus are needed using average daily temp as the variable.
    Sent from my DROID RAZR using Tapatalk 2
    Dec 2008
    Ontario Canada
    Using a nice Honeywell IAQ stat, set cycle rates down as low as possible, then added a 10 min delay after stat energizes second stage, disabling second stage was a fun little test
