Results 1 to 11 of 11
Thread: more winners
    Apr 2001
    more winners
    A few pics from this fall.
    If you can't get the secondary pan level, put the float on the high side. It keeps the float dry, so it lasts longer. The customer knew there was a problem when it leaked through the ceiling.
    Quality duct system.
    Jason
    Apr 2001
    Unsupported domestic water expansion tank.
    Crawl space condensate pump
    Jason
    Apr 2001
    Weil McLain Ultra Boiler, leaking everywhere.
    Doggie potty, where I need to work.
    Jason
    Apr 2001
    I never saw this before. The pressure reducing valve failed and overfed. The relief valve failed and didn't open. I saw 50 psi, who knows what it was when it was firing. Customer came home to green paint on the washer, and a slow drip. After I replaced the tank, relief valve, and feeder, the pump didn't work, either.
    Jason
    Apr 2001
    Tenant: Furnace is in the basement, you'll see it.
    I itemized every piece of junk I had to move to get to the furnace. Turns out, the tenants ripped down the vinyl tube from the condensate pump. Its under the broken chair, the weight set, the trim with nails...
    Jason
    Apr 2001
    Chimney liners, reducers, mortar... who needs them?
    Jason
    Apr 2001
    Un-cased coil, with a little panning. It was a 100,000 BTUH Goodman in a 50,000 BTUH house. The coil was too narrow, but it was in stock, I guess. I also got a good video of the flame rollout.
    Jason
    Dec 2010
    Vancouver, BC
    That's a dam good collection of some UGLY work.
    How did that joint holding up that expansion tank not break!?
    Rochester NY
    Lol, Seen expansion tanks installed like that!
    What an awesome collection!
    Whatsup w the ultra? They just crap?
    Oct 2005
    wow. what a mess
    RTFM!!!
    Dec 2011
    North Texas
    definately
