Results 1 to 11 of 11
    Jan 2012
    Confused Infinity Control Furnace Staging
    What is theory behind letting the SYSTEM determine furnace staging and allowing the FURNACE algorithm to control staging. Additionally, when is either setting best indicated to implement?
    So dealers can lower their bid by leaving the old round stat behind.
    Actually I hate seeing a board stage, even one with logic. Only a stat knows what the temp is, setpont, trend and can have the furnace respond according to real comfort needs of the house.
    Sent from my HTC VLE_U using Tapatalk 2
    Saint Joseph, MI
    i cant imagine many scenerios where you have an infinity controller installed and not let it control staging. maybe if you had an aftermarket zone control.
    Grand Rapids, MI
    what are you getting at, the furnace is too slow to respond or too quick to respond ?
    the infinity control has the best algorithems of all the manufactors.
    luck dan
    Jan 2012
    Forgot to mention that I have no intention of changing any settings that may cause undesirable results and conditions.
    Jan 2012
    The furnace ignites and blower ramps up within acceptable time after the inducer begins. The high stage running at full bore is awesome. However, does the furnace data and formulas ever need to bypass certain functions of the controller?
    Jan 2012
    In addition to Hi, Med and Low, there are the two other stages that can be set with the ICS. I agree, allowing the control take over would seem the better choice. Must be why it is the default setting.
    Saint Joseph, MI
    Quote Originally Posted by Caleb View Post
    No its a fully integrated system.
    Sent from my DROID RAZR using Tapatalk 2
    Nov 2012
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
    Saint Joseph, MI
    I think the newer Infinity controllers use the outdoors sensor on the Infinity condenser, if installed... at least mine does. It also displays coil temp, so while not as good as hte actual sat. refrigerant temp, you can still use that info to gauge you can roughly guage approach temps so you know if the coil is getting dirty. The condenser if a heat pump, I think would use that info to decide when to go into defrost. WIth stright AC, I think it will use coil temp for low ambient operation.
    remtre5, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
