Results 1 to 13 of 16
    New England
    Hi - I had a new Evolution A/C system put in last January. The outside compressor is a 598B unit on a plastic pedestal. I recently noticed that the back of the unit (where the connectors are), is about 1" lower than the front. Should I care?
    If I should, what's the best way to level it? I don't think it can be tipped very far without disconnecting it. I could take a 2x4 (or 2x6) and shave it to the right width and slip it under the pedestal (or perhaps better, between the unit and the pedestal), or (how would I do this?) tip it up far enough to push enough dirt under it to level it?
    I know a concrete slab would be better, but my old unit was on a plastic pedestal for almost 20 years without incident, so I cheaped out (also, I've seen small slabs shift as well).
    I'm actually having my new A/C guys out to do the leveling, I'm just curious what they –should- and –should not- be doing. Just trying to learn.
    Thanks!
    /j
    Nov 2000
    Waco, Texas, USA
    squirt a little water under the high side and it should level out right before your very eyes.
    "And remember my sentimental friend......that a heart is not judged by how much you love, but by how much you are loved by others" - Wizard of Oz.
    New England
    huh?
    Rapid City, SD
    The water will wash away some dirt, and also help compact the stuff that stays there... you lower the high side, it'll (eventually) become even with the low side... that would make it level
    VETO PRO PAC, The Official Tool Bag of HVAC-Talk.com
    Testo... you guys rule!
    Mar 2006
    NORTH HAVEN ,CT
    Talking
    IF YOU WATCH IT LONG ENOUGH IT WILL GROW .
    New England
    I don't know - we just had a week of torrential rain, and the low side is under an overhang, but the high side gets a lot of rain - you mean just take a hose and force it under until it's level? I could try....
    beats raising the low side.
    I thought you guys were kidding, but this actually works? (or are you just pulling a HO's leg?)
    /j
    NW burbs of Detroit
    C'mon.
    Use some paving stones or other stone material to bring up the ass end. That'll do temporary.
    We push six by sixes under the pad to elevate the cond and
    build up the area for a permanent fix.
    Nov 2000
    Waco, Texas, USA
    Not kidding Jeff. It works very very well. Just squirt water hose back and forth just under the edge of the pad where it meets the dirt and it will start sinking right away.
    By the way your house will do the same thing if you don't divert the gutter down spouts at least 4 ft. away from the footing.
    Oct 2005
    sacramento calif.
    be sure its not a heatpump, in which case you want it tilted an inch or so to better drain defrost water. since its the same compressor either way & to answer your question...no you shouldn't care.
    New England
    It's for A/C only - so i shouldn't care if it's off-level by an inch?
    Rapid City, SD
    An inch really won't matter much at all
    burlington county n.j.
    1" will not matter much but it would be better if low end was away from house.
    Florida
    Thanks!
    /j
    Who's doing the work again Jeff???
