Results 1 to 4 of 4
    Jul 2012
    Greenville SC
    titus vav box heat issue
    im new to the vav game< i have a titus vav box, non fan powered 3 stage heat, controller is calling for 100% heat, no control voltage to contactors. line voltage is there and transformer is good. my question is: does the control board send signal to the transformer to on the secondary side to power the contactors. all the safetys are made but still no power? i guess I'm asking how does the controller send the call to the transformer?
    Jul 2003
    Orange County N.Y.
    It doesn't send a call to the transformer. The BMS system sends a signal to a control, the control sends a signal to a relay, which closes a set of points, which activate something. Transformers are usually in VAV boxes to power whatever board the operating system uses.
    I read your post as the controller (VAV box) not communicating with the BMS.
    ...Ron
    Roof Rat
    Dec 2010
    Downingtown, PA
    captaincallback
