Results 1 to 13 of 27
    Sep 2010
    Fayette, MO.
    Daikin’s VRVIII system
    I'm the maintenance supervisor for a small university. We have started changing our old 1920's steam heating systems to ground source heat pump systems a building at a time,But real estate available for wells is in short supply.
    We are looking to renovate a resident’s hall that is 55,000 sq ft, 5 floors, containing 180 room. We had a contractor tell us about the Daikin’s VRVIII system as a better choice for heating and cooling.
    Can anyone tell me if the Daikins systems is a good substitution for a ground source system?
    Mar 2009
    Mid-Mo
    What kind of tonnage of ac and btus of heat are you thinking you will need?? That many square feet would require a lot of systems. If I remember right, with a Daikin you can only put 3 modules together to make 40 tons.
    Mount Airy, MD
    Thread relocated to AOP
    Sep 2010
    Fayette, MO.
    I’m sure we will use multiple zones on each floor if not individual room units. Total tonnage may be somewhere around 150.
    I see you are from Mid Mo. We are in Fayette.
    To the admisistrator thanks for redirecting the thread.
    50
    North GA
    Interesting thread, I do not install this kind of system, however do use Daiken products at a small level.
    If I were in your shoes, I would find a second co that makes this kind of product, and get them working with each other to inform you of all the details.
    As I understand; Mitsubishi makes a line called 'city' that is similar.
    Please keep us informed as to how this turns out.
    GA-HVAC-Tech
    2 Chronicles 7:14
    Mar 2009
    Mid-Mo
    Ya the Mitsu multi city is the other one we have. Seems they both work well, like most things in this trade, as long as they are installed correctly.
    If you are from Fayette, you might consider getting a bid from TMI out of STL. I think they are the biggest Daikin guys around here.
    I'm actually not too far from you at the Lake of the Ozarks!
    North America
    We are doing a 300 bed residence right now using Mitsubishi city multi.
    Sep 2010
    Fayette, MO.
    Both the Daikin’s and Mitsubishi look interesting
    But in our application with all rooms being exterior with very little interior spaces except hallways we will be either in heating or cooling modes
    With ground source I like the idea of storing energy in the wells, (Cold) when heating and the (Warmth) when cooling. With either the Daikin’s or the Mitsubishi, energy, whichever heat or cold is blown off to the atmosphere. Down side to ground source cost of insulation and long term payback. The Mitsubishi system talks about savings in installation using the special valve box where Daikin’s uses a third pipe.
    Looks like when it comes down to it, Its all about the $$$$. And the time required to install.
    North GA
    Be interesting to see how the costs vs payback compare... Small shops like me do not get to see much about these BIG systems... they are interesting though.
    GA-HVAC-Tech
    2 Chronicles 7:14
    Sep 2010
    Fayette, MO.
    I'm afraid that in our case either the Daikin’s or the Mitsubishi system will be nothing more than a air to air heat pump system given the fact that all the rooms will be exterior. Attached is a floor layout showing the proposed addition. Again this is a 5 story building, no basement, 55,000 sq ft.Original structure built in the 1850’s, little to no insulation. It does have new double pain windows.
    Float'N Vally, MS
    Quote Originally Posted by 50Panhead View Post
    For individual room control.....
    The Mitsu or Dalkin may be a little pricey?
    Compaired to "other" systems.
    They can (heat pump) heat and cool at the same time.
    You will have to look at the insulation factor also..
    Interesting, we have only used them for smaller projects, like a fire house.
    Life is too short, Behappy!
    TFMM
    Sep 2010
    Fayette, MO.
    Our prefered system would be ground source heat pumps. The size of the building (doing some rough math) would require around 67 wells 400 feet deep and about 36 heat pumps of about 4 tons each.
    Eugene, Oregon
