Results 1 to 13 of 27
Thread: Daikin’s VRVIII system
12-07-2012, 09:57 AM #1
I'm the maintenance supervisor for a small university. We have started changing our old 1920's steam heating systems to ground source heat pump systems a building at a time,But real estate available for wells is in short supply.
We are looking to renovate a resident’s hall that is 55,000 sq ft, 5 floors, containing 180 room. We had a contractor tell us about the Daikin’s VRVIII system as a better choice for heating and cooling.
Can anyone tell me if the Daikins systems is a good substitution for a ground source system?
12-07-2012, 05:34 PM #2
What kind of tonnage of ac and btus of heat are you thinking you will need?? That many square feet would require a lot of systems. If I remember right, with a Daikin you can only put 3 modules together to make 40 tons.
12-07-2012, 06:01 PM #3
Thread relocated to AOP
12-10-2012, 08:25 AM #4
12-10-2012, 11:31 AM #5
Professional Member*
- Sep 2005
- North GA
- 17,308
Interesting thread, I do not install this kind of system, however do use Daiken products at a small level.
If I were in your shoes, I would find a second co that makes this kind of product, and get them working with each other to inform you of all the details.
As I understand; Mitsubishi makes a line called 'city' that is similar.
Please keep us informed as to how this turns out.GA-HVAC-Tech
2 Chronicles 7:14
12-10-2012, 12:49 PM #6
Ya the Mitsu multi city is the other one we have. Seems they both work well, like most things in this trade, as long as they are installed correctly.
If you are from Fayette, you might consider getting a bid from TMI out of STL. I think they are the biggest Daikin guys around here.
I'm actually not too far from you at the Lake of the Ozarks!
12-10-2012, 01:10 PM #7
- Dec 2005
- North America
- 203
We are doing a 300 bed residence right now using Mitsubishi city multi.
12-10-2012, 03:26 PM #8
Both the Daikin’s and Mitsubishi look interesting
But in our application with all rooms being exterior with very little interior spaces except hallways we will be either in heating or cooling modes
With ground source I like the idea of storing energy in the wells, (Cold) when heating and the (Warmth) when cooling. With either the Daikin’s or the Mitsubishi, energy, whichever heat or cold is blown off to the atmosphere. Down side to ground source cost of insulation and long term payback. The Mitsubishi system talks about savings in installation using the special valve box where Daikin’s uses a third pipe.
Looks like when it comes down to it, Its all about the $$$$. And the time required to install.
12-10-2012, 05:14 PM #9
- Sep 2005
- North GA
- 17,308
Be interesting to see how the costs vs payback compare... Small shops like me do not get to see much about these BIG systems... they are interesting though.
GA-HVAC-Tech
2 Chronicles 7:14
12-11-2012, 08:47 AM #10
I'm afraid that in our case either the Daikin’s or the Mitsubishi system will be nothing more than a air to air heat pump system given the fact that all the rooms will be exterior. Attached is a floor layout showing the proposed addition. Again this is a 5 story building, no basement, 55,000 sq ft.Original structure built in the 1850’s, little to no insulation. It does have new double pain windows.
12-11-2012, 09:15 AM #11
- Feb 2006
- Float'N Vally, MS
- 1,601
For individual room control.....
The Mitsu or Dalkin may be a little pricey?
Compaired to "other" systems.
They can (heat pump) heat and cool at the same time.
You will have to look at the insulation factor also..
Interesting, we have only used them for smaller projects, like a fire house.Life is too short, Behappy!
TFMM
12-11-2012, 10:15 AM #12
Our prefered system would be ground source heat pumps. The size of the building (doing some rough math) would require around 67 wells 400 feet deep and about 36 heat pumps of about 4 tons each.
12-11-2012, 10:56 AM #13
