Results 1 to 13 of 19
    Dec 2011
    Delta T for Ahu, Chiller and district cooling systems
    Hi all..Can anyone please explain me the concept of delta T & what delta T shall be considered for Chillers, Ahu & district cooling systems?
    And how it shall be calculated and considered?
    Regards
    Mount Airy, MD
    Thread relocated to AOP
    Dec 2011
    Quote Originally Posted by Chris_Worthington View Post
    What is AOP?
    Quote Originally Posted by mohsinrkhan86 View Post
    What is AOP?
    Ask Our Pros.
    Dec 2012
    Houston
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Dec 2011
    Quote Originally Posted by Catherin View Post
    District cooling systems can replace any type of air conditioning system, but primarily compete with air-cooled reciprocating chiller systems serving large buildings which consume large amounts of electricity.
    But what are delta T values for different systems to consider?
    Dec 2012
    Houston
    Dec 2011
    A delta-T is the change in temperature of a single substance or flow of substance. The evaporator delta-T is the temperature difference between the air entering the coil and the air leaving the coil.
    Yeah i know what delta T is. But i heard that there are pre-specified values of delta T for different types of systems like ahu, chiller etc
    Dec 2012
    Houston
    Jul 2003
    Orange County N.Y.
    Yes, there are specific Delta T parameters that are engineered into any given equipment.
    I've seen reach in coolers designed for 5 degrees delta for a specific purpose. I've seen chillers run from 10 to 20 degrees delta T, as well as air handlers. you will have to research each individual piece of equipment to find what the design Delta T is soposed to be.
    ...Ron
    Roof Rat
    Catherin, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    Dec 2011
    Quote Originally Posted by rscamaro View Post
    ...Ron
    Thanx rscamaro for your response.
    Another doubt, more the delta T value, better is the system. Is it true?
    Not necessarily.
