Results 1 to 13 of 30
    May 2012
    Confused connecting power to heat strip
    I have a HKR-20C strip for Goodman 4 ton package heat pump. The instructions are not real clear about connecting power.
    Says connect to terminal blocks. DO I use a jumper from block 1 to block 3 then 2 to 4?
    Oct 2008
    Indianapolis
    No
    May 2012
    I only have two power wires for the 240v
    High voltage is dangerous so dangerous, Do not attemp install or repair without calling a reputable hvac company.
    May 2008
    Missouri
    This is not a DIY forum. We can't help you with this. Sorry
    May 2012
    I got a Professional to install..I get home from work, now fan runs all the time..bad luck for me
    Quote Originally Posted by man00 View Post
    Just because you got a company to install it does not mean it is proffesional. With that lets say it was done proffesionally things do go wrong with equipment so why would you try to repair it by yourself? It should be under warranty by instal company.
    Jun 2001
    +1
    May 2008
    Missouri
    make sure your"Fan" setting on thermostat is not set to "ON" instead of "AUTO". If it's on "ON" then the fan will run continuously.
    hope they installed 2 60 amp services .
    Go Trump
    Cincinnati, Oh
    If your unsure about the way your contractor installed something, you can post a picture of it, and we can tell you if it was installed correctly.
    We cannot help you DIY this though. If the point of your vist is to fix it yourself, then your out of luck. Do not expect any steps in fixing any problem, other than to call your installing contractor.
    What I will say, is there are certain applications where what it seems your describing is allowed, provided certain parts are used.
    "Just get it done son."
    Dad adjusted
    Tallahassee, FL
    20 KW? ??
    Hope your electric meter is bolted down so it doesn't spin off the wall!
    Houston,Tx.
    Quote Originally Posted by SBKold View Post
    20 KW? ??
