Results 1 to 13 of 30
12-07-2012, 01:02 AM #1
- May 2012
- 14
Confused connecting power to heat strip
I have a HKR-20C strip for Goodman 4 ton package heat pump. The instructions are not real clear about connecting power.
Says connect to terminal blocks. DO I use a jumper from block 1 to block 3 then 2 to 4?
12-07-2012, 03:58 AM #2
No
12-07-2012, 09:10 AM #3
- May 2012
- 14
I only have two power wires for the 240v
12-07-2012, 09:24 AM #4
High voltage is dangerous so dangerous, Do not attemp install or repair without calling a reputable hvac company.
12-07-2012, 01:21 PM #5
Professional Member*
- May 2008
- Missouri
- 2,645
This is not a DIY forum. We can't help you with this. Sorry
12-07-2012, 03:51 PM #6
- May 2012
- 14
I got a Professional to install..I get home from work, now fan runs all the time..bad luck for me
12-07-2012, 03:55 PM #7
12-07-2012, 05:39 PM #8
- May 2008
- Missouri
- 2,645
make sure your"Fan" setting on thermostat is not set to "ON" instead of "AUTO". If it's on "ON" then the fan will run continuously.
12-08-2012, 05:44 AM #9
- Jul 2006
- Virginia
- 3,744
hope they installed 2 60 amp services .
The governent can not give anything to someone that it has not first taken from someone else
12-08-2012, 09:11 AM #10
- Jun 2001
- Moore, Oklahoma
- 2,674
12-08-2012, 09:23 AM #11
If your unsure about the way your contractor installed something, you can post a picture of it, and we can tell you if it was installed correctly.
We cannot help you DIY this though. If the point of your vist is to fix it yourself, then your out of luck. Do not expect any steps in fixing any problem, other than to call your installing contractor.
What I will say, is there are certain applications where what it seems your describing is allowed, provided certain parts are used."Better tell the sandman to stay away, because we're gonna be workin on this one all night."
"Just get it done son."
Dad adjusted
12-08-2012, 09:29 AM #12
- Feb 2009
- Tallahassee, FL
- 4,705
20 KW? ??
Hope your electric meter is bolted down so it doesn't spin off the wall!
12-08-2012, 11:30 AM #13
- May 2012
- 14
all is fine now..the strip was wired wrong from factory..
