Results 1 to 13 of 22
Thread: What Fuse?
    New England
    What Fuse?
    Found this in a 3 year old 60hp supply fan frequency drive at a new account.
    nice!!!!!!!!
    true knowledge exists in knowing that you know nothing.
    TIP-O-TX
    Hey!, at least wire insulation matches the fuse label
    Mar 2009
    Mid-Mo
    No worries, they were trying to figure out what kept blowing the fuses by blowing it up.....
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by nick muniz View Post
    It's that attention to detail that separates a good tech from a great tech.
    May 2012
    Upper Michigan
    That's just a spare ground terminal, go ahead try it out!
    So Cal, Maui, & Kauai
    Fuseable link.
    Sep 2012
    NW Louisiana
    The more I see of things like this the less they surprise me. Never less, I like to see them. I like to think they will receive a Darwin Award someday.
    CT
    Mar 2009
    Mid-Mo
    Quote Originally Posted by nsula_country View Post
    CT
    This stuff is like looking at a car wreck, you just can't NOT look!
    Dec 2012
    Western Mass
    Quote Originally Posted by Joehvac25 View Post
    LOL!! I was thinking the same thing!! Either that or its just a 110V unit!! LOL!!
    Jun 2013
    canada
    wow! Trying to keep the fire department employed?!
    Feb 2013
    Phoenix, AZ
    Those are the fuses for the control transformer primary. One fuse remains, and the TX is a single-phase load, so it's still protected against overcurrent. If the transformer primary were to go to ground though, not so much. Not as scary as bypassing the incoming line fuses, but still entertaining...
    Feb 2013
    Lamar, SC
    I usually find a piece of copper just jammed in where the fuse goes. I once found one a piece of wire in one I knew the other tech did just a few days prior and called him about it. "I didn't have any fuses," was the response. Tell it to the judge when your on trial for negligible homicide.
    "If you've eliminated all other possibilities whatever remains must be the truth."
