Results 1 to 13 of 18
Thread: 422-D
    Sep 2012
    cape coral FL
    422-D
    so i was at the supply house today and watched a guy pull in with a **** box truck. picked up a Rudd 2ton 13s unit and and a walk in cooling unit. think nothing of it and go on with my day. so i go to subway Naples fl for lunch today and i see this guy next door and a little pizza place putting 422-d in the rudd unit help my thinking because idk?
    Oct 2012
    CA
    What is 422-d and what does idk mean ?
    R-422d is a refrigerant.
    idk is text-speak for I don't know.
    Oct 2012
    CA
    Thank you .
    Mar 2009
    Mid-Mo
    Sounds like the beginning of an adventure for him. There are a lot of things different from a refer unit an a standard ac. Seems to me he's gonna find out what those are the hard way.
    Oct 2012
    CA
    That looks like a interesting refrigerant . Is it any good ?
    Quote Originally Posted by 54885488 View Post
    Not a fan
    Capacity losses make it a poor choice for R-22 replacement.
    Sep 2012
    cape coral FL
    whats going to happen when he needs to defrost lol if he even gets up to temp.
    Oct 2012
    CA
    Ok i get this thread walkin evap unit with the rudd unit as the condensing unit . Thats so far out there i could not connect the dots .
    I've heard of it being done and I suppose that, given proper sizing considerations and environmental considerations (HVAC equipment like that typically don't have low ambient controls that refrigeration equipment needs) it can be made to work.
    I've never SEEN it and I think that I'd condemn it on the spot if I did.
    Much smarter to install the correct equipment for the tech AND the customer.
    Quote Originally Posted by hvacman2213 View Post
    Far easier than you think.
    Defrost could be accomplished with an add-on pressure control or an add on timer.
    Mar 2009
    Mid-Mo
    I predict no less than 2 trips a year to "fix" it. Customer probably wanted the cheapest job possible and that's what they got!
