Page 3 of 3 FirstFirst 123
Results 27 to 30 of 30
Thread: Calculating GPM
  1. #27
    May 2012
    Upper Michigan
    Quote Originally Posted by supertek65 View Post
    wow!
    thats the most i ever got!!!!!!!!!!!!
    Keep up the good work, 5 stickers gets you a cookie with frosting at lunch!
  2. #28
    8th grade
    I have already read far above my potential!!!
  3. #29
    May 2012
    Upper Michigan
    I guess you get 2 more stickers for effort, what the hell I mean now days the fat kid gets a prize ribbon for trying anyways! This was unexpected so I ate the cookie already! Whoops
  4. #30
    Mar 2012
    Georgia
    Find the cooler gpm in the Manufacturers IOM book. There will be a minimum & maximum GPM graph where you can plot your FT./head. You will need to get cooler entering water psi & cooler leaving water psi (use very accurate gauge, do not rely on the gauges installed on piping) use the pressure drop X 2.31 to find FT./head. ex. 30psig cooler inlet, 25psig cooler outlet= 5psi pressure drop X 2.31= 11.55 FT./head. Your should be able to plot this on the Graph to find out if you are moving enough water (per manuf.) through your cooler.
