Results 1 to 13 of 30
Thread: Calculating GPM
    Dec 2012
    Calculating GPM
    Hello all. New to the site, been in the trade about 15 years. Got a new employer, and we do work on chillers ( air cooled screw, scroll, and recip). How do you know you have proper water flow (gpms) through a chiller?How do you know what it's supposed to be? I appreciate feed back. I tried to do a search on here, but came up empty.
    Mar 2009
    Mid-Mo
    The iom manuals of the machine will tell you the design gpm, minimum and maximum for that particular machine. At the machine using the same gauge to measure supply and return pressure with the chiller at full load, you apply this formula:
    Gpm across barrel
    Gpm (actual)=design gpmx(square root of actual divided by design)
    A=234 x sq rt of 4/6
    2.5 gpm per ton for chilled water
    look at your pumps and read gpm and head
    if pump is correct and gpm is correct
    find out what the pressure drop through the chiller is supposed to be
    if it is correct
    then
    use
    gpm x 500 x delta t
    this should get you close
    then you will have to learn approach.
    frank
    true knowledge exists in knowing that you know nothing.
    May 2002
    A lot of Ioms will have a graph to assist you in calculating GPM.
    Design can vary per application .
    There are rules of thumb.
    There are math calculations to perform .
    I'll look around and see if I can come up with something for you....
    mikeacman
    Mar 2009
    Mid-Mo
    Quote Originally Posted by supertek65 View Post
    if it is correct
    then
    use
    gpm x 500 x delta t
    frank
    Ya I forgot the part about the pump. Oops!
    Thought I was gonna get an atta boy from ya....ya not!
    Mar 2011
    Long Beach, CA
    Here it is.
    Dec 2012
    You guys are awesome. Thanks for the replies.
    Mar 2011
    Long Beach, CA
    Take a look at this.
    when you can snatch the pebble from my hand!
    it will be time for you to leave grasshopper!
    http://www.youtube.com/watch?v=gASY7Lj5GPQ
    Quote Originally Posted by ryan1088 View Post
    May 2012
    Upper Michigan
    Bruce lee got the shaft on that one!
    i think you are correct!
    of course they are both dead now!
    i looooove bruce lee!
    have you ever seen him play ping pong with wooden matches???????? FREAK!!!!!!!!
    Quote Originally Posted by Joehvac25 View Post
    May 2012
    Upper Michigan
    I have seen the old ping pong videos, he's the ****. If you want your bubble burst read the book "bruce lee unsettled matters".
    They found David in a bad spot lol.
