Results 1 to 13 of 23
    Oklahoma City, OK
    carrier 90% furnace
    Im having trouble figuring out why this 6 year old furnace wont close the pressure switch?
    Feb 2012
    Toronto Canada
    Is it stuck open?
    Is the venter motor working?
    Oklahoma City, OK
    the venter motor is working and I have replaced the pressure switch
    Oklahoma City, OK
    It seems to have to much negative pressure acording to out digital magnehelic guage. we taken off both the flue and freshair intalke and no change
    Oklahoma City, OK
    carrier 90% furnace
    Ive replaced the pressure switch and cannot get the furnace to close the pressure switch. any ideas? ive removed the flue and fresh air intake and it did not change any thing.
    Nov 2012
    Check the vacuum to the switch, maybe the line is plugged up or there is water in furnace due to a plugged drain.
    Oklahoma City, OK
    Quote Originally Posted by joeblo View Post
    Checked all of that and thats not it. this is a very unusual situation and hard to figure out. Not a typical trouble call!
    Dec 2011
    San Antonio, TX
    Believe it or not, the furnace drain can cause this! The corrugated hoses have to be switched based on left or right flow. They are tagged different colors with description on the panel.
    Ontario
    Those corrugated hoses also can crack, and it can be difficult to spot. Be sure to check them.
    Question authority!
    Jun 2012
    Rising Sun, Maryland, United States
    pressure swith could be DOA
    May 2012
    Upper Michigan
    What's your pressure compared to the switch? Is it a differential ps?
    Nov 2012
    The first thing is how much vacuum the furnace pulls with the intake and exhaust off. The drain could cause this problem. The secondary could be plugged, but this normally trips the roll out. make sure the black intake box under the burners is not plugged with a bird nest etc.
    May 2011
    My bet is that there's a gallon of water in the secondary. Good old Carrier drain traps. I have days where I un-clog 3-4 of those in a row.
    Pull the flex hose off the top of the drain trap.
