    Australia
    Mech/Hvac electrical drafting & project managing
    Hey all,
    I'm hoping to start drafting (hvac control electrical cct design etc) at the company I just started at, and I wanted to see if anyone had any ideas to help make my drawings better. (and add some wow factor for the boss )
    I already plan to use the standard where the wire number tells you what page, and line it appears on, and I'm also fond of putting in a semi-transparent image of the controller and overlaying the wiring diagram on that (which helps with less experienced installers), and I'm also thinking about a sticker that gets stuck onto the controller showing some of this info too.
    Are there any ideas you've seen that you've really liked?
    All input would be welcome.
    I use autocad, but I've also used visio, but prefer cad
    The DDC system... guilty until proven innocent
    Jun 2006
    I like your idea of the wire numbering.
    I just spent time setting up a Visio template that uses an externally linked excel sheet/s to paste the points (or type) them in. Then when you update the Visio sheet the points show up color coded to type of I/o. You just hi light a shape and drag the data point up to the sheet and it auto populates the shape with color, numbers of conductors, and I/o type.
    Intelli-Building = Less Stress, commissioned with diligence!
    Dec 2006
    What? Who? Where?
    I found the following two books helpful:
    https://www.aeeprograms.com/store/de...&category_id=6
    http://www.amazon.com/HVAC-Control-S...=hvac+diagrams
    When I bought the second one it was still in publication and was reasonably priced.
    kontrol out
    "Open is as open does." - Forrest Gump
    "Can't we all just get a Lon?" - Garry Jack
    "BACnet: integration or interrogation?" - The Janitor
    "Open protocols? You can't handle open protocols!" - Nathan R. Jessup
    “What’s that? Aaa… open protocols? Don’t talk about…. open protocols? Are you kidding me? Open protocols? I just hope we can hardwire an interface!” - Jim Mora http://www.youtube.com/watch?v=U7fjDS0jKiE
