Results 1 to 12 of 12
    May 2012
    Upper Michigan
    Guess the problem
    Had to drive an hour one way to this gem, spot the problem besides the ignitor rig job. Lp gas.Name:  ImageUploadedByTapatalk1354754831.070960.jpg
    Dec 2012
    should be a negative gas pressure I believe, I've had a lot of issues with dirt with those heaters, had a pair next to a commercial clothes drier and would always takeout the igniters
    May 2012
    Upper Michigan
    It's not running, that's input
    Tallahassee, FL
    Out of gas? That said I have no idea what you are working on. Negative gas pressure? Huh?
    I like your manometer though. I have a similar one. :grin:
    May 2012
    Upper Michigan
    Quote Originally Posted by SBKold View Post
    Bingo, drive an hour to BFE, won't fire, go out the the 1000 lb tank and empty lol, luckily she was a milf. It's a munchkin boiler.
    May 2011
    tallahassee,fl
    Oh I luv the out of gas/oil calls, ranks just under water in the fuel oil tank
    Tallahassee, FL
    Somehow that always makes it better!
    May 2012
    Upper Michigan
    The other funny thing is I was in the doctors office reading a magazine called Great Lakes something, I read an article about her house in it a month ago then when I walked In the door I thought wow this looks familiar.
    Cincinnati, Oh
    New mod con boilers will show a negetive out of the gas valve.
    Remember those rooftops, where the inducer didn't suck THROUGH the hx, but pushed? Same thing on new mod cons.
    The gas/air mix in the inducer. So it goes Valve, air, inducer, hx.
    "Just get it done son."
    Dad adjusted
    Oct 2011
    Chicagoland Area
    Oh? Lucky for who? Certainly not for us.
    Rochester NY
    Sooted hx?
    May 2012
    Upper Michigan
    Ha ha lucky for her or I might have charged more though she was prolly rich.
