Results 1 to 8 of 8
Thread: Return Plenum and transition
    Nov 2012
    Hi
    I'm changing pretty much my whole system today. But the ceiling boxes. The are replacing duct work, supply plenum, AC furnace and coil.
    They are NOT replacing the return plenum and transition. They are saying it looks fine. I see that the insulation looks black from dust but they insist is fine.
    Should these pieces be changed or this won't affect anything?
    south louisiana
    I'd change it.
    some ductboard has black coatings
    sheetmetal insulation has black facing into plenum.
    return leakage contributes to high RH in our climate.
    this leakage is past the filter, so where this sucks in
    air it brings air/dust etc to collect on coil.
    dust is an indication of leakage. at the minimum
    clean off dust and make sure that they mastic seal all
    the connections.
    same with supply plenum connections and each supply duct take off.
    sealing supply boxes at ceiling will help reduce duct loss also.
    best of luck.
    Nov 2012
    Tahlequah OK
    How old is your system and how long of a run is your RA duct? Is it round or square duct? The duct insulation used years ago had a tar impregnated paper facing that turned dark over time. I agree with energy_rater that you should at least have them check the duct for air leaks. Take a look at the air entering side of the evaporator coil. If it is real dirty than you know you are bypassing the air filter somewhere which is most likely your RA duct.
    Nov 2012
    Quote Originally Posted by energy_rater_La View Post
    I'd change it.
    the connections.
    best of luck.
    They are changing the supply plenum. they are going to clean dust and they also are saying that the whole home purifier is after the return so that stuff is not going to make it to the system. They say it doesn't look bad.
    I don't know much about this stuff so I don't know what is bad or what is not.
    south louisiana
    if it is dirty..you have leakage. return leakage contributes
    to high RH indoors.
    if they don't want to do the work..they will
    say it is ok.
    are they using mastics to seal new supply plenum?
    don't let them duct tape of foil tape the leakage
    it might seal now..but later it will leak.
    we've seen other systems to base
    our answers upon. if the company wants
    to hurry through the sealing will be minimal.
    your costs to operate won't.
    best of luck.
    Nov 2012
    to high RH indoors.
    say it is ok.
    best of luck.
    This is what the coil looks like.
    They are going to mastic and seal all connections. Also the insulation look black because the material was black as somebody suggested. Should it be replaced anyway?
    south louisiana
    take a picture of it hard to see from here!
    welling service
    Please check your e-mail.
    Thanks,
    AOPC
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
