Results 14 to 20 of 20
    East of big city prices.
    I think I will just stick to Carrier branded products.
    Quote Originally Posted by valdelocc View Post
    try the Hoffman 865-3aa.
    May 2002
    Quote Originally Posted by Dallas Duster View Post
    I would have thought a MMV was less expensive.
    it might be , I had to make a decision as the unit was down ,the unit does not have an economizer ( I'm working on that sale ) and has a year round cooling load.
    Since it was under warranty the only option for free was to replace like for like ,I couldn't buy something else and return the failed part for credit ... The only way we get a credit from the carrier distributor is to buy a new part and return identical failed part for warranty credit .
    We are working on a solution ,,,,I have carrier involved .... We hope to get some or all credit for changing it to something else .
    I won't hold my breathe though ....
    The customer is a victim in all of this .... They paid good money for head pressure control .... And have gotten nothing but problems .
    The mm3 is installed 100% by the book , it should work reliably ,but is isn't reliable . It does work ,just not for more than 3-6 months .
    At this point I want to hear what carrier engineering has to say....the call is in ...waiting for a response.
    mikeacman
    Have you tried to run just one fan and see if the problem possibly happens? How old are those motors on the unit?
    I'm sure that guy from Carrier will help you is he from Kansas City area?
    Quote Originally Posted by mikeacman View Post
    May 2002
    I thought about it , wasn't really sure what to do with the other one . Let it run or cycle it . Being a slab coil with both fans side by side with no baffles in between I wasn't sure how it would be affected trying to overcome spinning backwards over time combined with continuous cycles.
    One motor is 6 months old and the other is around 2 years old.
    I've been busy traveling out of town to other jobs . I got them back online and have requested help . That's as far as I gotten at this point . A better permanent solution has to be found,I just need to find some time. I want to do this once and be done with it .
    I'm in southern Indiana , dealing with an independent carrier distributor, I have to run my questions thru them ,they contact carrier ,then relay it back to me ,rinse and repeat. I'm not sure who my support person is going to contact. Sometimes I can get a conference call and may ask for that.
    We are a large carrier dealer but that doesn't allow us to call direct ,I believe that's reserved for carrier building services only . We sell millions a year but still have to go the dealer route for assistance . It works ,but it just takes longer.
    mikeacman
    May 2002
    I know other options have been suggested , but both fans really need to be controlled , they are large fans with less than a foot dividing them , the coil is a slab and is not a big coil , and there are no baffles ,if one runs full speed the other is going to windmill backwards at a very high rate of speed ,then it's going to energize and have to overcome this time and time again . On a larger unit with more coil and fan decks this may not be an issue . I just feel it will be on this unit .
    I don't want to trade one issue for another. I would like an engineered solution to this if possible. I have a feeling I'm going to have to figure it out myself.
    mikeacman
    May 2002
    If my thinking on the backwards wind milling is wrong tell me ,I can handle it...
    mikeacman
    I will see what I can do.
