Results 1 to 13 of 20
    May 2002
    carrier motor master 3 problems
    I have a carrier motor master 3
    magnetek 3p-vs1 which requires the VS-101 motors which I have.
    I have an issue I have seen before and cannot remember the cause.
    The thermister is good
    At a certain resistance range ,which equals around 80F, the fans do not turn ,they just shake really bad and make a god awful noise . I can short the resistor so they run full speed and the motors appear fine.
    I know someone else has encountered this .
    Yes ,I know they are junk .....noy going to put mm5 on either . I want to know why...
    mikeacman
    May 2002
    I talked to magnetek...
    One or more triacs out of adjustment ....not field adjustable ....device is garbage
    mikeacman
    East of big city prices.
    Sure why???
    Quote Originally Posted by mikeacman View Post
    May 2002
    Quote Originally Posted by Dallas Duster View Post
    Sure why???
    I'm not sure what you mean ?
    Do you have an answer? Or am I not clear?
    I spoke with magnetek and they told me why it was doing this . I also spoke to carrier tech support and they didn't know . I also questioned the application and it was researched by carrier and I was told this is a valid option for the unit in question .
    This unit has had 4 of these in two years .
    I triple checked the installation and all appears correct . Yes , we are using the vs101 motors
    This is on a HJD025 500 series running 208vac.
    I can't get a good answer ,good enough for me ,and I'm thinking were going to have to go to something else . I have an email in with a tech support person who has promised to research this for me and let me know .
    mikeacman
    May 2002
    Magnetek told me it was triac adjustment issues or a triac failure, couldn't tell me why it failed but in the same sentence told me it was junk ..... and to replace it . When I mentioned having 4 in two years they questioned the application.
    We are running two motors off this , he wondered if the current was to high .
    I checked it with a trms meter and it appeared to be at or near max amps , but not over ....
    mikeacman
    This is what I am referring to.
    May 2002
    Well ,I would like to put the 5's on
    This is still a warranty issue ...not sure who's going to pay for what.
    The customer paid for a replacement in July and we warranty for a year P&L.
    I'm going to have to turn it over and let the money men decide this one.
    mikeacman
    Southeastern Pa
    P66 and be done with it.
    Junk is the reason.
    For 3 phase motors?
    Junk is the reason.
    I would have thought a MMV was less expensive.
    up in the hizzy
    Junk is the reason.
    the biggest problem with p66 is they leak after a while.
    up in the hizzy
    For 3 phase motors?
    try the Hoffman 865-3aa.
    Southeastern Pa
    For 3 phase motors?
    I missed that part. I was using my dumb phone.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
