    Nov 2012
    New York
    Andover Controls
    I have about 75 Andover Infinity I2 920 in service. On one of them all the inputs are reading 999.99. I shut the power down and removed the backup battery. I re-energize and reload the controller and I still get the same thing on the inputs. Is this something that is easy to fix or is the board shot and I need a new one.
    RGB
    Mount Airy, MD
    Thread relocated to the "Controls" section of the site.
    Quote Originally Posted by rgb3rd View Post
    RGB
    You might have a high voltage hitting the input buss causing all inputs to read 999. Try unplugging one of the connectors on the buss one at a time to see if that helps. if it does you have a bad input on the connector that is unplugged. I am not sure but my recollection is anything over 10vdc will cause that to happen. Good luck!
    Skean
    Nov 2012
    New York
    Quote Originally Posted by Skean View Post
    Skean
    Thank you for the reply and the advice. I did what you said one input at a time and still have the problem. I removed all the inputs and the problem did not go away. I powered it down and reset the controller and reloaded it and still have the problem. I guise I will have to buy a new controller.
    Thanks again
    Roy
    SE Wisconsin
    Did you also remove any input from the smart sensor input?
    How about putting a meter on the inputs and seeing what you have coming in?
    A few minutes can save a lot of cash if you haven't tried those yet.
    Ken
    Nov 2012
    New York
    Quote Originally Posted by chesehd View Post
    Ken
    Thank you Ken,
    There is nothing attached to the smart sensor input.
    I will try your idea and measure each input.
    Thanks again
    Roy
