Results 1 to 13 of 25
    Sep 2012
    thomaston, ct
    Navien 210 combi w/ first co. AH from wood conversion
    Before:
    Click image for larger version.
    After:
ID:	332361Click image for larger version.
ID:	332371Click image for larger version.
ID:	332381Click image for larger version.
ID:	332391Click image for larger version.
    Work completed by Steve Papp and Joe Lanesey of ECO home comfort systems out of Goshen CT.
    Dec 2008
    Buffalo NY
    Just why you did not pipe for combustion air? Or is that a concentric?
    To the man who always did it right. I love you dad and I will miss you to much for words.
    Stay Thirsty My Friends
    Support the Skilled Trades Don't DIY
    Sep 2012
    thomaston, ct
    Not a confined space, also louvered vent on opposite wall, adequate combustion air. Tanks being set this week. At that point we will do more testing to determine if we pipe outside.
    Dec 2008
    Buffalo NY
    Quote Originally Posted by jlanesey View Post
    Good looking job. Thanks for the explanation.
    Sep 2012
    thomaston, ct
    As long as there is no negative pressure we will most likely leave it as is. Also the way it was explained to me, if possible the unit will run better using a steady temperature for intake air. I didn't understand but the more I think about it I guess it makes sense. Pull anywhere from -10 - 105 degree air from outside or a steady 50-60 degree air from inside year round.
    May 2012
    Upper Michigan
    Looks nice but a valve and a drain on exp tank is great for service.
    Aug 2001
    Pavilion, NY
    Nice looking install. If your water temperature is above 140 degrees that PVC needs to be replaced with polypro or schedule 80pvc. The Propress fittings look great.
    Sep 2012
    thomaston, ct
    What PVC? The vent?
    Sep 2012
    thomaston, ct
    What PVC? The vent?
    Rochester NY
    Yes, the vent.
    Be good idea to call your Navien rep about the intake as well.
    Propane? Be wise to put in low pressure cutoff. Soot that thing and nobody will be smiling.
    Dark board looks awesome. Whats with the fiberglass in the window?!
    May 2012
    Upper Michigan
    Is that gas line copper? I've never seen that before Exept soft copper with flares.
    Rochester NY
    That's why I guessed propane.
    May 2012
    Upper Michigan
    Quote Originally Posted by tedkidd View Post
    That's why I guessed you guessed propane lol
