Results 1 to 13 of 19
    Nov 2012
    Dublin, CA
    A new type of furnace - The House-Burner-Downer!
    This is a wall furnace. A-may-zing.
    Wall furnace after I replaced it and ran a new thermostat line.
    That little misaligned flap in the upper right has been driving me batty ever since I noticed it in the picture. Maybe I should head over and fix it. "Hello ma'am and sir, my OCD demands entrance into your property so I can make your furnace cover flaps perfectly aligned again."
    NE wisconsin
    Wait a sec, is there something missing in that first pic? Glad you were able get them something safe.
    Jul 2002
    Chariton, Iowa
    Quote Originally Posted by philjafo View Post
    Only a 750 millivolt gas valve, not like you need it or anything.
    Aug 2008
    San Clemente, CA
    I really like the newer Williams too. That is a well engineered wall furnace.
    Nov 2012
    Dublin, CA
    Quote Originally Posted by JKopp View Post
    They are definitely a breeze to install and repair. It's my go-to brand of wall furnace. The furnace install took less than a hour. The ceiling plate spacers were the pain in the butt.
    Calgary, Alberta
    Glad those are banned in Canada!
    Nov 2012
    Dublin, CA
    Quote Originally Posted by syndicated View Post
    I guess I didn't give enough information. Those aren't legal here either. The homeowners had their furnace break down (probably the thermocouple not generating enough millivolts). They weren't sure how to fix it. So they decided why keep the middleman? and removed the regulator.
    S*** you not, even tried to light it manually. That must have been a... experience... for the homeowner.
    I'm thinking before he did it, he said something like "Hold my beer and watch this!"
    Aug 2008
    San Clemente, CA
    That 1/2" coupling in place of the gas valve also removed the regulator for 3.5" pressure at the manifold. So it was running at 7 or 8" pressure. Over fired for sure.
    The CPSC also published a warning about that uncoated brass gas flex connector. Our Gas Utility Co. Red Tags all uncoated brass connectors.
    http://www.cpsc.gov/cpscpub/prerel/prhtml97/97187.html
    Athens, Ohio
    HOLY COW!
    Apr 2010
    NC Sandhills
    WMD! Good thing you got to it soon enough.
    Jul 2013
    I guess we'd call the a direct fired unit??
    Mar 2013
    Did you remove the pilot connection? Was it a gravity system?
    Sep 2003
    I would have looked at it in amazement for a minute.
    Then I would have shut it off and capped it
    Williams makes a great direct vent heater....That's an electric heater right?
    Because I don't see any venting ......some are top vented.....some are direct vented
